Author Topic: Stock Engine Needed ..  (Read 1549 times)
Offline Lanny
« on: December 24, 2004, 12:50:23 PM »
I am looking for a stock aircared 1600S/P or D/P to rent/ borrow in the next few months. The new engine combo probably won't pass... :(
« Reply #1 on: December 24, 2004, 01:02:34 PM »
don't worry lanny, its a good thing :D
I might have what you are looking for in 2-3 months.
I'll let you know then, unless you find something earlier.
Stephan
PS:  what does the new combo consist of?
Offline Lanny
« Reply #2 on: December 24, 2004, 01:26:44 PM »
Considering my old combo wouldn't pass after 20 plus passes at Aircare, I'm outta luck.Bruce Tweddle made it REALLY close. The off idle problems w. IDA's are a real pain. The only parts from the last 2276 are the crank/rods, flywheel, P&C's, oil pump, straight cuts and a few other bits. The trans is completely redone also. Argh. :P
« Reply #3 on: December 24, 2004, 02:37:20 PM »
lanny, i've got a stock 1600s/p that came out of my oval.
it hasnt ran in 2 years (it's been out of the car) but it ran fine and passed aircare when it was last in. prolly needs a good tune-up.
you're welcome to borrow it to see if it'll work.
Offline Lanny
« Reply #4 on: December 24, 2004, 03:50:11 PM »
That would be perfect Silas.. I'll give you a shout when I'm closer to moving the car to the shop. I am doing some body touch up at work before installing the new motor. The trans should be installed in a few weeks. I'll have to drive it with a 1600, should be pretty strange :P Thanks.
« Reply #5 on: December 25, 2004, 12:17:43 AM »
no problem at all, lanny.
let me know when you need it.
