Author Topic: Automatic Hell!  (Read 4311 times)
Offline Hoosier Daddy
Automatic Hell!
« on: December 14, 2004, 07:27:24 PM »
The old square automatic is slowly playing out on me. Only gets up to about 40 mph then the engine revs and doesn't go any faster. It will go a little quicker if you only give it a little gas, but looses mucho power on hills.
I was planing on switching it over to a four speed this summer so I have a semi-decent pan that I can use but looks like I'll be doing it a lot sooner. (Like this weekend!) Anyone up for body some switching?
Oh well I'm sure the four speed will be a lot more fun to driver with the 1914.
Having a VW as a daily driver sure is fun sometimes :D
Automatic Hell!
« Reply #1 on: December 14, 2004, 07:40:31 PM »
I can give you a day! Let me know what your plans are.
Automatic Hell!
« Reply #2 on: December 14, 2004, 07:54:04 PM »
I can give you some day time hours ;) evenings are booked
Automatic Hell!
« Reply #3 on: December 14, 2004, 08:49:01 PM »
I'm busy all weekend. But there was a 68 fastback in the buy/sell with another auto pan, tranny. $500. I went and saw the car a while ago, pretty rough but all there. not a bad deal as it comes with that extra pan/tranny.
Automatic Hell!
« Reply #4 on: December 14, 2004, 08:54:18 PM »
got more details? maybe I can  save it from the chopper!
Automatic Hell!
« Reply #5 on: December 14, 2004, 08:58:41 PM »
i found it!
Automatic Hell!
« Reply #6 on: December 14, 2004, 09:02:43 PM »
Thanks guys, I'll probably just stick with changing it to a four speed.
Probably try and do most of the swapping on Sat.
Automatic Hell!
« Reply #7 on: December 14, 2004, 09:12:45 PM »
Crappy time of the month for this to happen Shane. Wish I could help ya out.
Automatic Hell!
« Reply #8 on: December 14, 2004, 09:14:09 PM »
after my morning run to airspeed I can come over and give you a hand.
Automatic Hell!
« Reply #9 on: December 14, 2004, 09:17:20 PM »
I work Sat but if you guys need parts or any tech info give me a call.
Offline reefreshd_jive
Automatic Hell!
« Reply #10 on: December 14, 2004, 11:53:23 PM »
saturday i am good to go.
Automatic Hell!
« Reply #11 on: December 15, 2004, 04:44:15 AM »
I thnk I can help out for a bit..... Need any tools/parts etc?
Automatic Hell!
« Reply #12 on: December 15, 2004, 06:41:34 AM »
Cool thanks guys. The wife had to get the square towed home last night...couldn't make the hil :o
Automatic Hell!
« Reply #13 on: December 15, 2004, 07:22:34 AM »
shane,
i would give you a hand as well but unfourtantly i have plans as well.hope everything goes well
russ
Automatic Hell!
« Reply #14 on: December 15, 2004, 07:36:27 AM »
What's the chances that the pan halves are good???
Automatic Hell!
« Reply #15 on: December 15, 2004, 07:50:23 AM »
Vulture :D  :D  :D
I might have to use them on the 4 speed pan....if not I'll send up with James.
Automatic Hell!
« Reply #16 on: December 15, 2004, 02:07:42 PM »
Shitty luck dude. Hope it goes well for ya. If I can help in any way just call.
Automatic Hell!
« Reply #17 on: December 15, 2004, 03:57:41 PM »
Vulture?? I prefer the word Buzzard. Always circling ;)  Thanks man. Appreciate it!
Automatic Hell!
« Reply #18 on: December 15, 2004, 04:04:50 PM »
Sorry man Saturday is out for me now , I forgot I am working  :angry:
Automatic Hell!
« Reply #19 on: December 15, 2004, 06:09:42 PM »
I got the 4 speed pan body off today....most of the front pan halves are rusted out so it looks like I'll be cutting the halves off of the automatic and welding them on the 4 speed pan...lots of work :D
Good news is that the square is pretty much rust free and all the body bolts should come right out. :rockon:
If I can get this done by next week do you think Chip will let me on Overhaulin??
« Last Edit: December 15, 2004, 06:11:07 PM by Hoosier Daddy »
Automatic Hell!
« Reply #20 on: December 15, 2004, 09:24:33 PM »
do you still need a hand on saturday? if so, what time are you thinking?
Automatic Hell!
« Reply #21 on: December 16, 2004, 08:45:12 AM »
I have found the answer to all my pan swapping problems :rockon:
Automatic Hell!
« Reply #22 on: December 16, 2004, 09:02:14 AM »
SO your running a hydro clutch....not swapping the pan?
Automatic Hell!
« Reply #23 on: December 16, 2004, 09:08:03 AM »
You got it. It's a pretty cool set-up. All you have to do is cut a 3\" x 4\" hole in the tunnel directly across from the pedals, the cylinder actually attaches to the original cable mount on the pedal, runs the lines and your done (Okay probablly a little more to it than that) but it's been done by others on T3 will little or no problems.
Automatic Hell!
« Reply #24 on: December 16, 2004, 09:09:19 AM »
SOunds cool, and no broken cables to boot. Are you able to set the pressure for pedal stiffness?
Automatic Hell!
« Reply #25 on: December 16, 2004, 09:13:44 AM »
Not sure if can set it or not. I did read that it makes the clutch pedal nice and easy even with a big racing clutch.
Automatic Hell!
« Reply #26 on: December 16, 2004, 05:45:35 PM »
Cool ! .......but what about the shift tube? Is there somewhere for it to exit the pan?  Access hole for the coupler?   Sorry.... Just thinking out loud
Automatic Hell!
« Reply #27 on: December 16, 2004, 08:41:25 PM »
It has the access hole for the coupler,,,,,just need to drill out a hole for the shift tube. I'll use the other pan as a guide.
Automatic Hell!
« Reply #28 on: December 16, 2004, 09:31:07 PM »
so what is the plan for saturday then?
Automatic Hell!
« Reply #29 on: December 17, 2004, 08:50:59 AM »
Not much of a plan for Saturday.....I'm kind stuck until the hydraulic clutch gets here. But thanks to everyone that offered to help me out :rockon:
