Author Topic: Carbs  (Read 4844 times)
Offline Kar-Mann
  • Junior Member
Carbs
« on: November 17, 2004, 11:00:19 PM »
I have a stock 72' Ghia 1600 dual port.  I am thinking of losing the orig. stock Solex and upgrading my carb. for something with a little more \"kick\". I am not that mechanically savy, so I am looking for something that will be simple and reliable with little required adjustments or maintenance.  I'm not building a racer, but would like to put a little more \"fire\" in the belly of my lil' Ghia.
I would be interested on any thoughts you guys may have on carb. options (centermount DB; dual SB; dual DB? etc.).  Kadrons, Webbers? - it's all new to me.
Also, if anyone is selling or has a line on some carbs and/or knows a good carb. mechanic for the install, that would be good to know as well.
Thanks,
Carbs
« Reply #1 on: November 18, 2004, 06:41:49 AM »
you should try Mike at Rudy Feeg @ 604 590 4409. Good luck.
Offline Kar-Mann
  • Junior Member
Carbs
« Reply #2 on: November 18, 2004, 08:02:43 AM »
Sick Ghia Red, what do you have for carburation?
D.
Offline Cameron
Carbs
« Reply #3 on: November 18, 2004, 08:40:59 AM »
Best bang for the buck:
Kadron / Solex kit, 009 distributor, and a header with a single muffler.
25% increase in horsepower, on a stock engine, maybe more.  And improved gas mileage, depending on how you drive.
All bolt on parts. If you have some hand tools, and a couple of hours, you may want to bolt everything on yourself.
Read more on Gene Berg web site.
CLICK HERE
« Last Edit: November 18, 2004, 08:48:17 AM by Cameron »
Carbs
« Reply #4 on: November 18, 2004, 05:24:56 PM »
For a stock engine, limit yourself to a pair of Kadrons.  Don't get a center mount progressive 2bbl carb.  All they do is increase your fuel consumption.
For the full effect you need a header and single muffler like Cameron says.
Carbs
« Reply #5 on: November 18, 2004, 10:31:41 PM »
Where are you located there are lots of good guys for install around.
Offline Kar-Mann
  • Junior Member
Carbs
« Reply #6 on: November 19, 2004, 09:19:14 AM »
I'm in North Vancouver, but North Surrey or North Langley is not a problem.
