Author Topic: Oil Leak  (Read 4326 times)
Offline Stevie
Oil Leak
« on: November 14, 2004, 11:11:54 AM »
i have oil leaking out of my front pulley on my bug,
all the breather vents are free. so why would it be leaking so much oil?
any help would be nice
Steve
« Last Edit: November 14, 2004, 11:12:14 AM by Stevie »
20's SORTA FIT!!
63 Beetle
Offline Cameron
Oil Leak
« Reply #1 on: November 14, 2004, 11:42:02 AM »
Pulley? Are we talking about an Air Cooled VW motor?
I always thought the flywheel was on the front of the motor!
« Last Edit: November 14, 2004, 11:43:22 AM by Cameron »
Oil Leak
« Reply #2 on: November 14, 2004, 05:37:58 PM »
did you change to a lighter weight eng oil.
have you allowed extra eng warm up time due to the cooler weather.
either that or your rings may be causing  excessive crank case pressure.
« Last Edit: November 14, 2004, 05:39:52 PM by jim martin »
Offline Cameron
Oil Leak
« Reply #3 on: November 15, 2004, 08:31:57 AM »
Do a compression test. Having oil come out of the case by the rear pulley is usually \"blow by\", rings going away.
Or did you over fill the engine with oil?
Oil Leak
« Reply #4 on: November 15, 2004, 10:11:34 PM »
Do a compression test. Having oil come out of the case by the rear pulley is usually "blow by", rings going away.
good point on the oil level .!
last year i had a ring issue and also always had oil coming out past the pulley due to high crank pressures.fixed the rings and stopped the oil pumping
