Author Topic: Oil Coolers Filters...  (Read 4966 times)
Offline B Easy
« on: October 25, 2004, 10:04:22 PM »
I have a custom oil cooler and filter... and i  hooked it all up and blew 2 seals on 2 bosch filters that i just bought... my engine is fine thank god cause its brand new and i just re did everything.. but i have 2 oil lines commin out of the block right where the engine mount is supposed to bolt on... if anybody has a set up and knows which way the oil flows could you please let me know.. or a way to find out without screwing my motor ;)... thanks guys
climbing_2000@hotmail.com
« Reply #1 on: October 26, 2004, 08:56:44 AM »
If you have 20w50 oil in your motor with a HD pump and a bosch filter you can blow them off fairly easy. Try using a HP1 (Fram) or similar filter. These have a double wall and will not blow off like the stock filters.
Oil line outlets on the pump should be marked as well as the filter bracket.
Offline B Easy
« Reply #2 on: October 28, 2004, 11:07:28 PM »
awesome.. thats exactly the set up i have.. ill give the fram a shot man... thanks a lot!!... oh .. i switched everything around.. it shoudl be fine... all the directions and everything are going well and the filter is on obviously... everything is correct.. but shes not running as well anymore...  do you have any suggestions on what i should do to make it better.. or what i may have done to screw something up.. thanks dude!
« Reply #3 on: October 29, 2004, 11:40:26 AM »
Nobody should be using 20W-50 this time of year.  If I was to do an oil change now, I'd use 5W-30.
