Author Topic: Weld Seals  (Read 4519 times)
Offline trevor421
Weld Seals
« on: October 08, 2004, 02:52:57 PM »
hi there. when i removed the winshield on my 73 bus, there was loads of rust and holes. so we did a transplant off my parts bus (the whole front window section down to the double thick part). it welded on nicely, and since my bus has been painted. i went to try and seal the weld from the inside today, and then i noticed (im pretty dumb) that you cant seal it from behind because of the metal being double think :o . is there anything you guys can think of to do? will it be okay for awhile, or is it just gonna rust away and my winsheild fall out???
thanks alot
