Author Topic: Heb Rod Updat #4  (Read 2144 times)
Heb Rod Updat #4
« on: October 05, 2004, 09:29:48 AM »
It's been a week or so since the last update and things are coming together.
Most of the week was spent building the roof and making it function. It needed to be widened, lengthend and made to attach to a factory VW vert header bow.  I spent a long time working on making the roof fold up inside the body and have enough room for a small back seat.
The first pic is of the parts I made to attach the header bow to the frame.  cutting,grinding, fitting, drilling tapping and some poor welds later. :)
In the second photo you can see the area that was lengthend, It also has a pivot point to allow the roof to \"Hide away\" under the body. The catches for the roof are from another European import and work very well.
Next I started work on the rear \"crotch coolers\"   These will duct cool air to the engine compartment.  The heb has no louvers on the eng lid and only a few above the lid for cooling. With this being more of a Hot Rod style heb I thought a set of period crotch coolers would do the trick.
Thanks to Matt for locating these coolers :rockon:
The crotch coolers are now controlled by the heater levers beside the e brake.
Now that the car is a vert it needs the door alignment wedges. This is the part before instalation.
Next was to start on the top of the rear 1/4. Once again I used a factory vert part to keep it looking stock. also you can see the wedge is now welded in place.
And the last pic of the update is the cold air pipes, these will run from a box around the crotch cooler to the eng compartment. One uses the heater tube and the other runs along the firewall.
More to come!
« Last Edit: October 05, 2004, 10:05:35 AM by Gkafer »
Heb Rod Updat #4
« Reply #1 on: October 05, 2004, 09:54:39 AM »
Wow G - Great work!
Offline hellgti
Heb Rod Updat #4
« Reply #2 on: October 05, 2004, 10:28:36 AM »
i'll be by so we can custom fab my flowmaster into my techtonics cat back system  :D
Heb Rod Updat #4
« Reply #3 on: October 05, 2004, 10:48:30 AM »
no prob
Heb Rod Updat #4
« Reply #4 on: October 05, 2004, 10:56:25 AM »
My god!! How many projects do you have on the go? maybe well see one of them finished next year? ;) Looks good Margret.
Heb Rod Updat #4
« Reply #5 on: October 05, 2004, 06:07:20 PM »
Quote from: Gkafer,Oct 5 2004, 08:29 AM
looks like everone is getting int 'RAM-AIR'
Heb Rod Updat #4
« Reply #6 on: October 05, 2004, 07:32:14 PM »
I,ve got a bus that needs work over the winter geoff maybe a lowering documentery for Hot vw's Say you could use my bus and one of your beams some of your free time it would be fantastic  :lol: Now let me do this for you geoff
!$#@#! off OUTKAST :lol:  :lol:  :lol:  :lol:  :lol:
Hey it was just an Idea ?
By the way project is looking good COLOR?
Heb Rod Updat #4
« Reply #7 on: October 05, 2004, 07:39:47 PM »
Hey Jim, Yeah it seem like people are doing more of this today. I put some under car ram air on my beetle i built in 1989 and it worked great. My red car and bus both have extra louvers behind the lic plates for a little extra cool air as well.
