Author Topic: Bus Trans In Beetle  (Read 1308 times)
Offline fullfenderbaja
Bus Trans In Beetle
« on: September 15, 2004, 11:10:59 AM »
hello all, I am new to  air cooled VWs.  I am hooked. I am putting  together a 75  baja full fendered. looking for hints on adapting bus trans. I already have an 091 gearbox. need to know whats best or whats easiest in terms of axles.  thanks
Bus Trans In Beetle
« Reply #1 on: September 15, 2004, 11:17:18 AM »
You can use stock axles or buy the sway a way axles. For the most part stock axles will do fine.
Bus Trans In Beetle
« Reply #2 on: September 15, 2004, 11:19:20 AM »
Which CV`s will be required to run the stock axles?
shawn
Bus Trans In Beetle
« Reply #3 on: September 15, 2004, 11:24:48 AM »
Bus T2 on the inner and beetle T1 on the outer, unless you swap the outer drive axle to a thing/944 then you can run T2 on the outer as well.
Bus Trans In Beetle
« Reply #4 on: September 15, 2004, 01:07:04 PM »
I was told the lenghts are  different. also something about removing a retaining clip for the cv. Thanks for all the replies.
