Author Topic: Compression Ratio  (Read 8584 times)
Compression Ratio
« on: September 12, 2004, 10:01:33 PM »
OK, I'm just pondering what compression I'm gonna run in the 2332. I have barrell spacers done, and the deck height figured. I was planning on using copper head gaskets as well which will yield a 9:1 ratio. If I pull out the coppers, that will bump me up to 9.7:1, with still safe deck height. Is it gonna be worth it to run a bit higher compression, or should I stick with the safer 9:1? I plan on running premium either way, and the car WILL be street driven as well. 911 shroud, with K-8 cam, and 044 CB heads with Kroc's touch.
Compression Ratio
« Reply #1 on: September 13, 2004, 09:11:22 AM »
I run a tad over 10:1 - weekend use only.
Compression Ratio
« Reply #2 on: September 13, 2004, 09:46:03 AM »
what kind of gas can you get over there?
i run my 2275 at 9.6:1 with no worries on 94 oct gas
Compression Ratio
« Reply #3 on: September 13, 2004, 11:02:07 AM »
94 at the pump.
Compression Ratio
« Reply #4 on: September 13, 2004, 11:06:15 AM »
I run on 94 Oct as well, no problems.
Compression Ratio
« Reply #5 on: September 13, 2004, 04:54:44 PM »
What is the deck height for both CRs?
Compression Ratio
« Reply #6 on: September 13, 2004, 07:57:56 PM »
.040\" without copper gaskets.
.070\" with the coppers.
Offline GMB
Compression Ratio
« Reply #7 on: September 14, 2004, 10:53:04 AM »
Hey Trevor. Run the .040\" and no copper torqued to 25ft lbs. You will be very happy! I am running 10.5:1 in a 2110cc with an engle 100 on 94 octane daily driven till the tranny went on holiday. With the K8 you could run 11.5:1 on pump gas with no problem. Tied together with Kroc heads and you would have an incredible engine. 9.7:1 will be excellent though. I know Brian Cook runs about the same compression (9.7:1) and runs 13.7  (Kroc heads) in the quarter on street tires and stock 4th gear in a fully dressed convertible Ghia. Allen U. is running High 11s with 9. somthing and Kroc heads in a full body 60s beetle. I know Brian is running .040\" deck hieght without the coppers and you would have to ask allen what he runs but I bet it is real close to .040\".
   Gary Massin-Ball.
Warrior sand rail:
2276cc 82x94
Single 40mm Kadron w/32vent
Equalizer 5lb pulley
Stock lifters
Stock aluminum pushrods
Compression Ratio
« Reply #8 on: September 14, 2004, 06:23:49 PM »
Yup , I'd agree with the .040\"  regardless of the comp. ratio  or if you use the copper caskets or not .  Based on what I hear and read ,  your engine  \" MAY \" run hotter and be more prone to detonation with .070\" deck  despite the lower comp. ratio .
Offline Sparkmaster1
Compression Ratio
« Reply #9 on: September 14, 2004, 08:16:37 PM »
If you have good steel rods .040 is a great  deck height for performance and tunability.  I  have a friend down here that runs 10 to 1 on a street 2332 and drives it daily with no problems.  He does use a slightly larger cam though.  Web 86b I believe.   What carbs do you intend to use?   Sounds like a great combination.  Tim.
Compression Ratio
« Reply #10 on: September 14, 2004, 08:54:12 PM »
Yeah, I'm running 84 CB crank with 5.5 CB H beams. Haven't bought any carbs for it yet (last big ticket item). Orginally was gonna run 48 DRLA tri-jets, but now 'am leaning more towards IDA's. Airfilters (or lack thereof)....that's the only thing I don't like about the IDA's. [_[
« Last Edit: September 14, 2004, 08:54:40 PM by Trevor P »
Compression Ratio
« Reply #11 on: September 14, 2004, 08:55:55 PM »
I'm pretty sure you can run an aircleaner on IDA's - you just wouldn't be cool though.
Compression Ratio
« Reply #12 on: September 14, 2004, 08:59:01 PM »
I saw that coming! :D
Yeah, I've seen those stupid looking little K&N pod put on top of the stacks...I say no!
I bet I would be cool if I had a set of oldschool NOS Empi airfilters for IDA's though! :lol:
Compression Ratio
« Reply #13 on: September 14, 2004, 09:00:05 PM »
Maybe a little....I really liked my old tri-jets they were nice carbs but nothing beats the sound of an IDA!
Compression Ratio
« Reply #14 on: September 14, 2004, 09:01:31 PM »
That is very true!
Compression Ratio
« Reply #15 on: September 14, 2004, 11:16:59 PM »
 :rockon: :rockon:
