Author Topic: Paint Colors  (Read 9566 times)
Paint Colors
« on: August 31, 2004, 08:09:58 PM »
anyone know a website that shows different vehicle paint colors?
Paint Colors
« Reply #1 on: August 31, 2004, 08:12:07 PM »
lol, you and your damn paint
for vw colors try wolfsburgwest.com
for other colors, i have no idea
Paint Colors
« Reply #2 on: August 31, 2004, 08:13:56 PM »
http://autocolorlibrary.com/acl_files/volkswagen.html
select a year & then click on the paint chips to view.
Paint Colors
« Reply #3 on: August 31, 2004, 08:40:16 PM »
paint
try this one ,i will have too find the others ,i came across 2-3 that were unreal ,let me see if i can locate them
click on 'paint'
« Last Edit: August 31, 2004, 08:41:11 PM by jim martin »
Paint Colors
« Reply #4 on: August 31, 2004, 09:34:54 PM »
Actually young man, my car will be one color, shiny paint this winter.....
Paint Colors
« Reply #5 on: August 31, 2004, 11:30:43 PM »
What do you guys think of this:
PAINT:
\"Copperhead Pearl\" from PPG
CODE COLOR CUMULATIVE PARTS
quantity: 1 quart.
DMD1698 Medium A 467.9 467.9
DMD1610 Transpar 809.0 341.1
DMD650 Sparkle 879.0 70.0
DMD1606 Pervlene 918.4 39.4
DMD648 Weak Bla 949.0 30.6
DMD646 Weak Whi 970.9 21.9
DMD622 Red Oxid 975.3 4.4
DBX1689 Basecoat 1027.8 52.5
Offline Needles
Paint Colors
« Reply #6 on: August 31, 2004, 11:52:28 PM »
Yikes :blink: Who's the lucky painter?? :ph34r:
Paint Colors
« Reply #7 on: September 01, 2004, 06:43:40 AM »
PAINT:
"Copperhead Pearl" from PPG
quantity: 1 quart.
love it
Paint Colors
« Reply #8 on: September 01, 2004, 07:40:24 AM »
Mr Slammedbus
Paint Colors
« Reply #9 on: September 01, 2004, 08:42:27 AM »
I thought it would look good on a bug - my orignal choice was a mouse grey but Jim's car is to close to it.
Offline Hoosier Daddy
Paint Colors
« Reply #10 on: September 01, 2004, 08:59:09 AM »
That's cool....Project Penny Bug!
Paint Colors
« Reply #11 on: September 01, 2004, 09:00:40 AM »
:) Never thought of that!
Totally describes my budget!
Paint Colors
« Reply #12 on: September 01, 2004, 09:05:50 AM »
James can you find a PPG code it should be DBC######???? If not I can mix it from the accumulative you gave but that means I would need to write it down........ :huh:
Paint Colors
« Reply #13 on: September 01, 2004, 09:11:55 AM »
Couldn't find the code according to the website it is a custom mix I only found this:
Copperhead Pearl Paint Code: By Stacey David & PPG. For further questions contact Auto Body Color and Supply of Nashville, Tennessee 615-726-0361.
Take this forumla to any PPG Distributor, and they'll do a custom mix for you.
quantity: 1 quart.
Paint Colors
« Reply #14 on: September 01, 2004, 01:50:23 PM »
Instead of the inch pincher we'll build the penny pincher :lol:
Paint Colors
« Reply #15 on: September 01, 2004, 06:04:06 PM »
you know what is kind of a cool solid colour is 'rock grey'
Paint Colors
« Reply #16 on: September 01, 2004, 06:29:53 PM »
Ya, now finding out what a metalic/pearl paint is worth I am leaning towards a solid color.
Paint Colors
« Reply #17 on: September 01, 2004, 08:23:09 PM »
here is a good point to look at when deciding paint colours,which in the end was a very key point in my decision.it is a car and at some time while you own it ,god forbid!!.they may be a need too do repare or touch up.if you choose a multy layer super fancy paint job it may make it impossible too match later on.since m.b uses standox i was going too use vw polar metalic  ,but found out that the yellow tint was not produced anymore.even thoe i located a pint,down the road a match would most likely become impossible.as many old tints are no longer used in modern paint codes.so i used a moden colour with tints that will always be around ,but changed up the metalic only,so down the road colour match should be easy.
also ,even if you use a solid colour a base/clear system is easier too blend in and repare spots if needed instead of a one step system.
Paint Colors
« Reply #18 on: September 01, 2004, 09:29:41 PM »
Good tip Jim.
Paint Colors
« Reply #19 on: September 01, 2004, 09:40:23 PM »
With the new proffit readers there is now the ability to make any paint in any shade.......Painters are using these to mix paints for repairs on vehicles that are now older and of course affected by UV light. Remember that the shade it is today may not be exactly what it is 5-10-15 years from now. Therefore mixing the original formula made it even more difficult for the refinisher to do a blend......James's copper color doesn't seem to be a tri-coat but rather a base clear with the pearl already in the base.....very common on today's vehicles
Paint Colors
« Reply #20 on: September 01, 2004, 09:41:36 PM »
There ya have it - CopperHead Pearl it is!
Paint Colors
« Reply #21 on: September 01, 2004, 10:11:11 PM »
Are ya sure now Mr. flashypants?
Paint Colors
« Reply #22 on: September 01, 2004, 10:26:29 PM »
Yup, getting a deal I can't refuse....
Paint Colors
« Reply #23 on: September 01, 2004, 10:44:28 PM »
its not the same as that crappy new pontiac colour is it
Paint Colors
« Reply #24 on: September 01, 2004, 11:13:13 PM »
Nope got the idea for the color from here:
http://www.truckstv.com/news.aspx?iid=2141
Paint Colors
« Reply #25 on: September 01, 2004, 11:16:17 PM »
I dunno, thats pretty close to crappy pontiac copper BLAH!
Paint Colors
« Reply #26 on: September 01, 2004, 11:22:29 PM »
What color is your bus there Kermit?
Paint Colors
« Reply #27 on: September 01, 2004, 11:28:39 PM »
green and white, thought that was obvious ?? hence your use of kermit.
Paint Colors
« Reply #28 on: September 02, 2004, 12:16:28 PM »
Apparently it is from a vehicle on Trucks (a show) and the vehicle was custom made from the PPG reps in Tenessee. Since the vehicle is called copperhead....the paint became Copperhead as well. It is not.....I repeat....not from a Pontiac....chev....ford...or any other res rocket. It is actually a real sweet looking colour :mullet:
Paint Colors
« Reply #29 on: September 02, 2004, 12:34:39 PM »
res rocket
Now that's funny! SPecially from you.
