Author Topic: WTB: Original Hardware  (Read 3496 times)
Offline Marcel
« on: June 19, 2023, 03:01:56 PM »
I'm looking for some good original hardware for my '56 beetle project. I'm not too concerned with which markings (ie: Kamax, Dorn, Knipping) as long as the threads are good and not too much corrosion.
Here's my list, I'll purchase any quantity you've got that's less or more than what I need or if you've got hardware you'd rather not go through I can buy that as well.
 QTY: 4 - M10x50mm - Bolts for body to pan mounting through front cross-member (Napoleon's Hat).
 QTY: 2 - M10x25mm - Bolts for body to pan mounting through rear quarter support to rear shock tower.
 QTY: 18 - 14mm head M8 "Special" bolts - Pointed body to pan bolts, The original ones I have that survived are 30mm long from underside of head to end of point.
 QTY: 36 - 14mm head M8x18mm - Fender mounting bolts.
 QTY: 4 - 14mm head M8x25mm - Fender to running board bolts.
 QTY: 20 ish each - M10 Bolts 10mm and 15mm lengths.
I have about 2 1/2 sets of original body to pan pointed bolts with 13mm heads that I can trade/sell. Plus this table of stuff can be traded/sold.
-KlassicFab Beetle rear RH quarter (new)
-Misc Cip1 1956 beetle brake lines (new)
-2x beetle 3 pin badges 113 853 601 B (original - used driver condition)
-90mm 40hp Bosch Dist.Cap 211 905 207 (original - used unknown working condition)
-Cip1 shifter bushing and clip (new)
-CSP weld in beam adjusters (new)
-Cip1 shifter stop plate (new)
-Misc dash/shift knobs, black shift knob is 7mm, white shift knob is 10mm (original used condition)
-Wolfsburg West weld in battery tie down plate (new)
-Rubber boots for clutch/throttle cable exit on chassis (1new 1nos)
-Shift boots later style VW markings inside (new)
-Wolfsburg West roller pedal (new)
-Oval window section, underside louver/decklid hinge panel removed and a section under the window on the inside is removed (original/used)
Thanks for looking!
Joe
2 Doors & Flat Fours
'56 Beetle
'00 Impreza RS Coupe
'16 Subaru BRZ
Offline berliner
Re: WTB: Original Hardware
« Reply #1 on: June 20, 2023, 08:28:49 PM »
I have a bunch of bolts I can go through, left over from my '60.Stay tuned for more.  Mike
Offline Marcel
« Reply #2 on: June 21, 2023, 12:51:21 AM »
Awesome! Thanks, Mike. I'll stay tuned.  :character0113:
'56 Beetle
'16 Subaru BRZ
Offline berliner
« Reply #3 on: June 23, 2023, 08:03:28 AM »
Looks like everything I have is wrong; if I come across anything I'll let you know.   Mike
Offline Marcel
« Reply #4 on: June 23, 2023, 08:52:25 AM »
No worries, thanks for looking!
Joe
'56 Beetle
'16 Subaru BRZ
