Author Topic: T3 And T1 Axles  (Read 6066 times)
T3 And T1 Axles
« on: August 26, 2004, 09:06:55 PM »
Am looking into buying a T3 IRS pan and wishbone for my 64 square......if I do this will a beetle tranny and axle set up work or will I need IRS axles from a T3???? Anyone know???
T3 And T1 Axles
« Reply #1 on: August 26, 2004, 11:18:52 PM »
I think the trany and axles will work ok in theory ..........but  ,  you have another problem . The IRS type 3  torsion housing does not provide any rear mounting for the trans . No trans frame horns like swingaxle cars have .   IRS cars have the eng & trans hanging from the nose cone at the front and the body at the rear.  Your 64 body will not have those mounting points at the rear .  This will be a challenge for sure .
allthough  ,  if just want to use the pan because it's good you could use your old swing axle housing on the new pan and keep it a swing axle car.
« Last Edit: August 26, 2004, 11:25:00 PM by Hansk »
T3 And T1 Axles
« Reply #2 on: August 27, 2004, 07:35:47 PM »
I have fabbed the t2 cross engine mount to go into my bumper bolt holes. Is this what you meant or am I still missing it. I will be going T4 power :unsure: ........so I was hoping that this mount would solve this problem....any input???
T3 And T1 Axles
« Reply #3 on: August 27, 2004, 10:22:39 PM »
AH HA , yes thats what I meant .  Sorry , didn't know you had that figured out already . So yes T1 & t3  std trans and axle shafts are the same other than the front ruber mount and the hockey stick ( shift tube set screw)   and the nose cone should be regular beetle style not late beetle style(73 & up)  Hope that helps .  Sounds like a cool project .
T3 And T1 Axles
« Reply #4 on: August 29, 2004, 04:58:08 PM »
Right on Thanks Hans. I was going to go T4 power on my notch project so I am looking forward to finally doing it on the square. This info does help......now if I can just find an IRS pan and wishbone........this is proving to be difficult... [_[
