Technical
Transmission Forum
Hydraulic Clutch's
Topic: Hydraulic Clutch's (Read 20448 times)
wagonwx
AirSpeed Forum Member
Hydraulic Clutch's
January 06, 2023, 06:03:14 AM »
How do these install and how exactly do they work? Is the clutch/pressure plate still the same or does that need to be changed with the kit? I need to custom make a clutch cable for the new project, and thought this may be an option.
52 split
Re: Hydraulic Clutch's
January 08, 2023, 07:53:36 PM »
the only thing that changes is you need a hydraulic clutch pedal assembly, usually with a brake pedal and a slave cylinder that attaches to the trans and run a line between the both. more money than a cable.
Technical
Transmission Forum
Hydraulic Clutch's
