Author Topic: Beetle performance and stock engine parts  (Read 2174 times)
Offline Dannyrds
  • Junior Member
« on: August 04, 2021, 08:34:38 AM »
74mm Cast counterweighted crank, VW Journal, new in box - $180
200mm Cast lightweight flywheel, new in box - $75
AA heads, 40 x 35.5 stainless valves, single HD springs, 85.5 bore, new in box - $500
Engle FK7 cam, new in box - $110
Empi IN/OUT oil pump, full flow without modding case, new in box - $45
7” H4 conversion headlights, with bulbs, used but excellent condition - $25
Stock machined flywheel, stock weight, ready to run, 4 dowel - $65
Stock dual port heads, need a good clean up, useable, used - $150
Stock 85.5 mm pistons (1600), good useable - $50
1600DP intake manifold, stock, need a good cleanup - $50
Stock 69mm crank with gears and rods - $100
Stock 1500 piston and cylinder set - $75
Stock rocker arms - $25
1 3/8 header, used, needs a coat of paint- $40
Stock oil pump from 1500 - $20
Stock oil pump from 1600 - $20
Single relief case, good useable case, needs machining - $250
2 x stock camshafts and lifters - $40 each set
Text 604-834-4007 for pics or questions
Dan
Offline vwguy
Re: Beetle performance and stock engine parts
« Reply #1 on: August 04, 2021, 05:56:38 PM »
PM sent
