Author Topic: drilling 36hp. flywheel for 8 dowel pins  (Read 2650 times)
Offline hank
« on: July 19, 2021, 08:22:13 PM »
Howdy gang.
We are rebuilding  a 36hp engine for our "57 beetle and would like to get the heads done and drilling the flywheel for 8 dowel pins
Are there any machine shops in BC that does that kind of work?
thanks
Hank
Re: drilling 36hp. flywheel for 8 dowel pins
« Reply #1 on: July 20, 2021, 09:25:48 AM »
a friend from the island just got his back from that shop in Spokane that does VW stuff. Was very pleased if there's not someone local.
Offline hank
« Reply #2 on: July 20, 2021, 02:47:02 PM »
thanks
I have a brother in law in Spokane I'll see if he knows of them
I had some other work done at a Kamloops machine shop and will try get in touch with them
I have the jig for the 40 hp /1600 size dowel pin but is too big for that 36 flywheel,
cheers
Hank
« Reply #3 on: July 20, 2021, 03:08:51 PM »
this was some of the info Hank
Title..... VW Engine Case Machining
Price..... 20
User...... Vintage Volks Speed Shop
Name...... Jeremy Noble
EMail..... jnoble@vintagevolks.com
Phone #... 5099989734
Location.. Spokane Valley, Washington, USA
Description:
Is your old VW motor getting a little tired? Is it time to pull it and rebuild? Vintage Volks Speed Shop is here to help! Specializing in aircooled VW's, we are a full service VW Machining Shop offering  services for all aircooled VW motors, including 36 HP and Type 4! All services performed in house. See list below. Visit us at VintageVolks.com or call us directly. 509-998-9734
Line Bore - $75
Thrust Cut - $50
Cylinder Bore - $95
Case Savers - $120
Stroker Clearance - $120
Shuffle Pins - $75
Hoover Mods - $80
Full Flow - $50
Valve Guide - $20
3 - Angle Cut - $20
Dual Springs - $10
Stem Seals - $20
Dowel Pin Repair - $25 per hole
Case Cleaning - $50
If you would like to see this ad in detail:
https://www.thesamba.com/vw/classifieds/detail.php?id=2424664
If you would like to see all ads from Vintage Volks Speed Shop:
https://www.thesamba.com/vw/classifieds/search.php?username=Vintage+Volks+Speed+Shop
If you would like to edit your alerts or unsubscribe, visit the Alerts page at:
https://www.thesamba.com/vw/classifieds/alerts.php
Offline hank
« Reply #4 on: July 21, 2021, 09:42:26 AM »
thanks for that Bwaz    interesting
cheers
Hank
