Author Topic: Which Dropped Spindles Do I Need?  (Read 4352 times)
Offline slugbug
« on: August 24, 2004, 05:56:49 PM »
I bought the SO CAL(AC INDUSTRIES) Wide 5 disk brake kit(from classified section) from nivag. I want to get king/link dropped spindles for it. Should I be getting the ones for drum brakes? Since this disk brake kit has the caliper brackets to mount to a stock beam. Will these work: SPINDLE PICS ?
ps: Russ did a nice job powder coating these :)
« Last Edit: August 24, 2004, 06:00:07 PM by slugbug »
[/a]
« Reply #1 on: August 24, 2004, 06:07:32 PM »
i'm not sure you can run drop spindles with that kit Geoff or jim will have to chime in though to be sure.
russ
ps thanks
Offline Hoosier Daddy
« Reply #2 on: August 24, 2004, 06:23:00 PM »
Your only option is to go adjustable beam to lower it.
Offline slugbug
« Reply #3 on: August 24, 2004, 06:28:38 PM »
Thats what I was thinking too. Thought I'd make sure first though. Thanks guys  :)
Now to get an adjustable beam and shocks :blink:
[/a]
« Reply #4 on: August 24, 2004, 06:33:24 PM »
Then SLAM it :!:
Offline slugbug
« Reply #5 on: August 25, 2004, 07:19:33 AM »
Then SLAM it
With the condition of the Quebec roads, that's what I'll be doing allright. That and rattling teeth. :wacko:
I'm thinking I should use airshocks all around  :rockon:
[/a]
