Author Topic: Front Drum Rubbing  (Read 1401 times)
Offline reefreshd_jive
Front Drum Rubbing
« on: August 23, 2004, 12:26:48 AM »
just a quick question, i installed my new drop spindles this morning, but when i took it for a test drive the passenger side drum seems to make a rubbing sounds, and also when i back up i can hear, and feel it!
could one of my wheel bearing not be sitting right?
thanks for the help
james
Front Drum Rubbing
« Reply #1 on: August 23, 2004, 08:07:11 AM »
is it your tire?
Front Drum Rubbing
« Reply #2 on: August 23, 2004, 09:20:11 AM »
I remember on my first set that one of the lower ball joint bolts rubbed a little on my rim, I just cut it down and retapped it.
Offline hellgti
Front Drum Rubbing
« Reply #3 on: August 23, 2004, 09:25:47 AM »
whats rubbing on what?  is the drum rubbing the backing plate? or like james said, rim rubbing a bolt???
Front Drum Rubbing
« Reply #4 on: August 26, 2004, 08:26:31 PM »
thanks for the input. it was just the lower ball joint rubbing the rim..and it turns out my grease nipples also broke off...oh well...it is driveable and i get to go to everett.
thanks
james.
Front Drum Rubbing
« Reply #5 on: August 26, 2004, 08:50:00 PM »
Fix the rub prior to the trip, you'll be sorry if you don't!
Also make sure to plug the broken grease nipple - don't want crap in you beam.
