Author Topic: 55 36hp Run On Unleaded?  (Read 5558 times)
Offline slugbug
« on: August 21, 2004, 02:04:25 PM »
Is it safe to run unleaded with a '55 36hp engine?
Or  should I have the heads rebuilt with updated valves, seats and guides.
[/a]
« Reply #1 on: August 21, 2004, 03:01:27 PM »
Perfectly safe.  Don't even think about it anymore.
« Reply #2 on: August 21, 2004, 04:30:18 PM »
ya, what he said.
Offline coolairX2
  • Junior Member
« Reply #3 on: August 31, 2004, 07:20:27 PM »
I have always run my 58 Ghia on high test - 93. I never have tried to run it on 87 what does everyone else use?
-Craig
« Last Edit: August 31, 2004, 07:20:38 PM by coolairX2 »
« Reply #4 on: September 01, 2004, 02:02:34 AM »
If your 58 Ghia still has a 36er in it, you are not only wasting money, you are giving up precious hp.  That's right, your low compression engine will make more power with low octane.
My own engine is 2 liters with 40 Dellortos, 'bout 120 hp.  With 8.5:1 compression ratio, I only give it 87 octane.  Runs great that way.
Offline coolairX2
  • Junior Member
« Reply #5 on: September 16, 2004, 06:10:58 PM »
Well I did build the 36hp and bumped the CR to 8.5-1 not the normal 6.?-1.  I had a Judson installed which I caculated to be about 10:1 so I need every bit of the 93 with the Judson.  Without the Judson it does run fine with 87 or 89.
-Craig
