Author Topic: 36HP Big Bore stroker engine "build kit" sold  (Read 1761 times)
Offline J A Red
« on: September 21, 2018, 03:44:40 PM »
I've been collecting parts over the last year to build a big bore stroker 36hp engine, but with the sale of the car it was going in, I will no longer be building this. here is what is included.
Case - late '55, fully prep'ed, chem treated and machined for 80mm P/C by Mr Okrasa
DPR 69.5 36hp crank counterweighted balanced w/ lightened flywheel and pressure plate includes main and rod bearings
Stage 2 cam with straight cut cam gear set from Aircooled Research
Rebuilt 36hp Rod set from Aircooled Research
Custom made RaceWare head studs for 36hp w/ DP cylinder heads
Wolfsburg West Dual Port cylinder heads machined for 80mm P/C by Mr Okrasa
Custom made SS larger valve set - 35mm intakes 33mm exhausts
H/D valve springs from Aircooled Research
AA Pistons 80mm Big Bore kit P/C
Speedwell USA intake Manifold (for 40PII, Dellorto or Weber)
Gene Berg 36HP oil sump
WW pushrods
Stainless Steel push rod tubes
a pair of 36mm Dellortos fully restored
CB performance H/D oil pump for 6mm studs (not pictured)
Restored 36hp fuel pump (not pictured)
Also includes a gasket kit and top quality main seal.
All these parts are either brand new or fully restored and have not been used. The crank has been assembled with bearings and gears, Cam and gear have also been assembled.
Price $5,750US or $7,400CDN
I will not part anything out at this time, however if you would like this without the carbs, manifolds and larger valves, we can discuss that. My price is pretty firm and I am not looking for any trades. I am willing to ship anywhere at buyers expense. Will deliver to Lower mainland BC. Serious inquiries only.
https://www.flickr.com/photos/153448150@N04/shares/w048Lw Link to some pics
« Last Edit: October 12, 2018, 07:38:26 PM by Reed Green »
‘59 Light Green Double Cab
Sherbet Orange Meyers Manx
Offline J A Red
Re: 36HP Big Bore stroker engine "build kit"
« Reply #1 on: October 07, 2018, 06:36:27 PM »
deposit taken
Offline J A Red
Re: 36HP Big Bore stroker engine "build kit" sold
« Reply #2 on: October 12, 2018, 07:38:05 PM »
Sold
