Author Topic: Hazard Switch help  (Read 14280 times)
Offline s3racing
Hazard Switch help
« on: June 10, 2018, 09:55:29 PM »
Probably a silly ?
On our classic beetles are the hazards only on when the ignition switch is on. I would think they should be over constant power mit Ignition switched or am I wrong here?
Thanks for any help
Cheers René
Re: Hazard Switch help
« Reply #1 on: June 11, 2018, 01:43:54 AM »
On late Beetles, the 4 ways work with no key in the ignition.
The strangest thing is the headlights.  On some late cars the headlights will go out when you turn the key off (but the running lights stay on).  Then on others, the lights can be on mit the key in your pocket.
My June 74's lights go out when the key's off, but my Aug 74 (MY 75), the lights stay on.  My brother's 73 Super's lights went off with the key.  My 72 Super's lights stayed on.
Jag, what do your 75's lights do?
Offline s3racing
« Reply #2 on: June 11, 2018, 06:50:59 PM »
Weird my power to the hazard switch is constant but they only work when I Have the key in the ignition inthronisiert run position.
