Author Topic: Wtb: Late Squareback Tow Hitch  (Read 1633 times)
Offline Hoosier Daddy
« on: August 17, 2004, 03:12:27 PM »
Need a tow hitch for a late IRS type 3.
Shane
« Reply #1 on: August 17, 2004, 05:51:53 PM »
I thought you sold the square?
« Reply #2 on: August 17, 2004, 05:53:26 PM »
The square was almost gone, a last minute protest by my great wife allowed it to stay :D
Offline slugbug
« Reply #3 on: August 17, 2004, 06:23:39 PM »
Don't think anyone makes a Type 3 towbar, so you might have to have one custom made.
Found this info on the samba forums :
The super beetle tow bar makes a very good start. You add a single strip of 1 1/2" angle iron to one side, and drill 2 holes in it and bolt it to the bottom of the beam. You add two pieces of 1 1/2" tubing to the tow bar tubes and your done. If you get one of the better ones, they come with quick disconnect pins at the ends. This set up only eats up about an inch to 1 1/2inches of ground clearance, and can be left on all the time if you notch it for the grease zerks.
[/a]
« Reply #4 on: August 17, 2004, 07:52:51 PM »
I think he wants to tow with the square not tow it behind somethin.
Offline slugbug
« Reply #5 on: August 18, 2004, 06:38:46 AM »
oops  :huh:
[/a]
Offline volksbug
« Reply #6 on: August 18, 2004, 09:53:21 AM »
I have a tow hitch off a late beetle conv.  Frame horns are same width so only length would be in question.   Marcel
« Reply #7 on: August 18, 2004, 10:45:45 AM »
Shane, you can talk to Penguin(Mikey). He has one on his square. Im sure hed be more than happy to show it to you.
« Reply #8 on: August 18, 2004, 12:03:21 PM »
If I can get pictures I can make it for you shane
