Author Topic: 1967 Bus question  (Read 2874 times)
Offline Lanny
1967 Bus question
« on: April 02, 2018, 07:55:29 PM »
Where is the wiper switch located on a 67 Bus? Same as earlier models?
Re: 1967 Bus question
« Reply #1 on: April 02, 2018, 10:07:59 PM »
yes! as per my bentley workshop manual for 63-67 transporters. it also notes, since 2 august 1965 from chassis # 216 000 001 all transporters have been fitted with a two speed windshield wiper motor and the former push/pull switch has been replaced by a rotary switch with 3 switching positions (left off, center slow, right fast).
also just for s#!ts & giggles...from thesamba.com technical section a 1967 (August 1966) Owner's Manual...
 :cool:
Offline Lanny
« Reply #2 on: April 03, 2018, 05:50:41 AM »
Thanks Silas. I searched online with no results.
I’m wiring up a bus with a new 66/67 harness, the wiper wiring will not reach the switch.
I suspect the wiper motor position may be the culprit.
Offline Herrlowlight
  • OldBusBoy
« Reply #3 on: April 12, 2018, 08:32:52 PM »
.. Lanny, I can swing my '67 by if you need to take a look
Trevor
1968 912
1958 Kombi
