Author Topic: SGVWA Swap Wish List..APR 8  (Read 17444 times)
Offline billybob57
« on: February 28, 2018, 07:47:17 AM »
Anyone looking for something special??
Offline Scooby
Re: SGVWA Swap Wish List..APR 8
« Reply #1 on: March 01, 2018, 07:10:13 AM »
S0-42 cargo door table,and a standard horn button for a bug
Offline gsun
« Reply #2 on: March 01, 2018, 10:28:20 AM »
Early bay sunroof panel.
9 years and counting....
Offline flemcadiddlehopper
« Reply #3 on: March 30, 2018, 09:18:30 AM »
 I will be coming down from Kelowna for the swap.
  Short list of bits coming with me: -set of 5 like new (never seen the road) CIP Empi wide 5s , 15" x 5.5".
                                                   -l and r early bay rear fender repair sections.
                                                   - bay rear hatch snap-in mosquito netting  x2
                                                   - split bus floor x-member and out riggers
                                                   - set of 4, 14" factory steel 5 x 205 bus wheels
                                                   - one 15" 5 x 205 steel bug wheel.
                                                   - set of new H-beam rods 5.5", chevy journal
     and, i will be bringing the infamous Bamboo/Carbon Fibre VDM Replica Steering Wheel as a show piece.     https://youtu.be/pXPRzP4_i14
I once caught a fish this big.
« Reply #4 on: March 30, 2018, 09:28:53 AM »
  What I am looking for: Under dash tray for '64-'67 bus.
                                   Any '67 bus bits.
                                   '64 beetle steel sunroof parts, crank handle and cable tubes, or more.
                                   Any early ('80) Vanagon Riviera Camper interior parts.
                                   Split bus front safari window conversion set.
   Gordo (the other one).
Offline saltspringbus
« Reply #5 on: April 03, 2018, 10:47:12 AM »
I'm looking for interior bits for a 78 Westy.
Front door panels
rear bumper,
some cabinet / interior "wood" panels & table
drivers door (original paint Dakota beige) and excellent
also for a 71 deluxe bus
front emblem (must be excellent)
drivers door (must be chianti / pastel) original paint and excellent
Offline Lanny
« Reply #6 on: April 03, 2018, 09:02:30 PM »
Looking for;
Full size Santana pulley(mint)
1 5/8” 4 Tuned header
1 X stock 4 bolt Beetle wheel
Ghia BJ spindles
Michelin 145’s and 165’s
Clean factory valve covers
60’s factory steel sunroof clip
66-67? Bus decklid handle(3 screw)
Tang style 12V top pulleys
« Last Edit: April 05, 2018, 08:03:16 PM by Lanny »
Offline 72vwtype2
  • Phil
« Reply #7 on: April 03, 2018, 09:36:17 PM »
Looking for stock parts for my 58 bug:
Rear dimpled fenders
6 volt generator, starter and voltage regulator stamped 1P.
Stock rims stamped 1/58
1972 Kombi
1964 Vespa 150
« Reply #8 on: April 04, 2018, 08:23:10 AM »
- Front 1959 wire tube fenders (left and right).  These are 1959 only (1958 has a slightly wider hump and pressing on the fender beside the headlight bucket) unless you have clean 1960-1963 ones that I can weld a lower wire tube onto - Only looking for Original german fenders
- 1958-1959 Headlight assembly with screw terminal running light
- Front fender turn signal assemblies with screw terminal bulb holders (chrome, lens and bulb holder all must be in very nice shape)
- 6v screw terminal horn (working)
- 1957-1960 Fuel tank (with 4 pressings on the front) - Must be extremely clean inside with fuel cap
- Original VW running boards - mats don't need to be in good shape, but they must be original german and solid.
- Left front Canadian standard seat for 1958-1964 (wing nut attachment)
- Front wolfsburg hood crest (4 brick style)
Offline 68bluebeetle
  • AirSpeed Forum Member / Bug Restorer
« Reply #9 on: April 05, 2018, 10:37:07 PM »
1957 oval bug parts
namely: under gas tank extra switch over for the last gallon of gas...including the lever under the dash to switch
             white switch knobs from dash left and right of radio delete
             blaupunk radio with am fm and euro band
             original shifter knob
             three spoke steering wheel horn
             batwing type steering wheel 9no horn button)
             original gas tank
             front signals
             pea shooter tail pipes
             signal arm
             two sided sun visor with translucent flaps
             other misc 50s parts
Stephen B
68bluebeetle@gmail.com
11 bug owner, restorer, engines builds X 5
Offline kinggeorge13
« Reply #10 on: April 06, 2018, 08:03:20 AM »
Any parts of the FI system or whole FI system for late bays.
Calipers, master cylinder, other brake parts for late bays (anything 1973-79)
Cabinets, cabinet doors, sink, water tank, fluorescent light, water pump (for the sink), etc.
Working wiper motors
Wiper controls (1973-1979)
Sliding door parts: lower track, lower bracket (with working rollers), the shims that go between the lower bracket and the bottom of the door
Sliding door latch and latch mechanism/lock
Sliding door center hinge sliding door (the part that runs along under the right rear window and pulls the back of the door shut)
Bus/Westfalia curtains (Bays)
Westfalia mattresses/cushions (1973-79)
Broken/dead Beetle speedometers
1975 Westy, Serenity
1975 Westy, Jack Sparrow
1979 Kombi, Pistachio
1979 Kombi, Oliver
1977 Tin top camper, Cosmos
1974 Westy, Garfield
1974 gutted Riviera, Casper
1975 Westy, Stella
1979 Super Beetle, Penelope
1967 Fastback, Green Hornet
« Reply #11 on: April 06, 2018, 08:49:47 AM »
The chrome housings and lenses are they the sharp corners or the rounded versions, not sure what’s early and late, I’ll look through my boxes if I can help out I’ll letcha know
Offline pittwagen
« Reply #12 on: April 06, 2018, 09:11:42 AM »
68bluebeetle here is your reserve tap.  Shaft is tight but moves freely.  Screen is intact.  Rubber is not cracked.  Was spare for my 57 std. sunroof. $40cdn.
« Reply #13 on: April 06, 2018, 10:09:56 AM »
I believe the european "puff" signals (up to 1960) had the sharp corners, but our north american cars all got the rounded ones...I believe
Thanks Kevin!
« Reply #14 on: April 06, 2018, 10:39:25 PM »
here is a list of stuff i need!!
mostly parts for a split bus...but some parts are interchangeable through different years & types so please see descriptions...
- link pin shims for '63 and earlier bus, i need approx 15 of them
- emergency brake shoe lever, left side, i need 1 (they are side specific, fits mar '55 to '71 bus)
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211609613B
- brake push bar, left side, i need 1 (they are side specific, fits mar '55 to '71 bus)
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211609631B
- brake shoe star adjuster stud, i need 2 (fits mar '55 to '79 bus)
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211609209A
- brake shoe star adjuster, i need 2 (fits all bug & bus)
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113609205A
- emergency brake pivot pin, i need 2 (fits all bug & bus)
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211609601B
- magnetic trans drain plug, i need 2 (the 17mm hex head type, pretty sure fits most beetles & buses?)
 :cool:
Offline xtracold
  • Junior Member
« Reply #15 on: April 07, 2018, 10:40:15 AM »
I need a left hand side rear trailing arm for '74 IRS Ghia suspension.
Anyone out there with a '70's Ghia they are parting out I would be very interested to talk to, i'm in the middle of a body off restoration so need a lot of stuff!
« Reply #16 on: April 07, 2018, 05:17:08 PM »
I've got an email early bay westy flip up table and a pair of nos beetle 68-70 tail lights. Lenses and housings if anyone is interested I can bring them out
« Last Edit: April 07, 2018, 08:45:22 PM by bwaz »
Offline Cluster
« Reply #17 on: April 07, 2018, 07:25:22 PM »
Looking for late split bus in case some has some items collecting dust..
- sunroof/ragtop mechanism any condition/bits
- belly pans
- front seat covers for walkthrough
- eis safaris
Thanks!
« Reply #18 on: April 08, 2018, 08:33:46 AM »
all packed up & ready to roll! see you all at the swap meet! :cool:
« Reply #19 on: April 08, 2018, 09:28:35 PM »
big thanks to the sgvwa for organizing and hosting a really great event!! the turnout was huge, the swap was packed with lots of great parts and it was really cool seeing everyone and getting caught up!!  :cool:
