Author Topic: FS: 1600 Dual Port Parts - Main and 17th Vancouver ** All sold **  (Read 1561 times)
Offline paolo
I've got the following, taken off my engine after running it for about 500 milers last summer:
1641 Slip-Fit P/C's, about 500 miles on them - $100
Pair of New Chinese Stock 1600 Heads, about 500 miles on them - $200 for the pair
Dual Port Manifold with EMPI 34 PICT/3 Carb - $50
2 x 1600 Heater Boxes - Free
1600 Rear Apron Tin with hole for Heat Hose, wide type - Free
Doghouse Shroud, sandblasted, 1 cm tear at throttle tube hole $40
Pair of Finned Aluminum Valve Covers $20
Lower Sled Tins - Free
Many Thanks
« Last Edit: June 09, 2017, 06:03:51 PM by paolo »
Offline blacksc
Re: FS: 1600 Dual Port Parts - Main and 17th Vancouver
« Reply #1 on: May 24, 2017, 10:05:58 PM »
What can you tell me about the heads?
Offline paolo
« Reply #2 on: May 24, 2017, 11:29:49 PM »
You can check with AVR but I'm pretty sure they are these ones:
https://www.cip1.ca/ProductDetails.asp?ProductCode=VWC-043-101-355-CKHL
500 miles or so on them. Car ran great but I had to pull cases apart due to low oil pressure at idle.
Offline blacksc
« Reply #3 on: May 25, 2017, 07:50:09 AM »
I wonder if I can bolt these onto my 1200.
Offline paolo
« Reply #4 on: May 25, 2017, 08:36:51 AM »
I would research this but I doubt it; Even 1300 to 1600 poses challenges... I may be wrong.
Offline OldnShitty
« Reply #5 on: May 25, 2017, 12:09:37 PM »
Hey, are the heater boxes still available?
Offline paolo
« Reply #6 on: May 26, 2017, 08:59:42 AM »
Yup, they are... PM me pls for address....
