Author Topic: FS: Split bus odds and ends  (Read 1714 times)
Offline dale-j
  • Steve
« on: May 20, 2017, 01:46:27 PM »
Seven (!) black dash grab bars for split bus.  I was told they were NOS but they are definitely dirty and a bit shelf worn.  Anyone want to start a business selling these on the Samba let me know.  You have a turbo stroker split bus without seatbelts, and your passengers keep tearing these out of the dash, I'm your guy.  $50 for the pile or make an offer.
split bus wiper arms.  One early straight tipped (marked VW and SWF), one late curved tipped (just marked VW); $10 each
Fried egg front signal.  Outer lens is broken, inner amber lens and bulb holder (Hella) would be useable on a rat (err...patina) bus.  Seal is there too.  $5
63+ rear brake/turn lens.  All red.  OG SWF / vw stamped on the chrome and lens, bit of cracking by the lower screw hole that's not bad and could be used on the above noted 'patina' bus.  Chrome is decent, includes the seal $5
Late split/early bay back up light housing and chrome bezel.  No glass.  Die cast Hella housing has the VW 111 941 071b stamp on it (Type 1 part number) but the chrome bezel is the thin one (and in good shape) to mount to a bus.  $5
12 volt Hella German horn.  Tested good.  Flat connectors with the round seal mount on them.  <pending to Brian>
Steering column brackets.  One has a gray half bumper around the nose, one has a filthy white bumper with it that looks to go all the way around (?)  $10 for both.
two chrome headlight rings.  Came with the bus and are either bus, or both right side ones from a beetle.  No markings, one with a small dent but definitely serviceable on a character vehicle and both have adjusting screws and brackets.  <pending to Brian>
More odds and ends to come I'm sure.
Steve
« Last Edit: July 28, 2017, 09:36:34 AM by dale-j »
Offline dale-j
  • Steve
Re: Split bus odds and ends
« Reply #1 on: May 22, 2017, 10:29:21 AM »
Beige Grey turn signal switch HLS 10-51a marked SAE Q61 SWF  9 wires
wires are cut and needs a good cleaning inside and out <pending to Alp>
Black one is only marked SWF and I think was for oval window beetle.
SIX (sorry not four like I said before) wires (wires are cut on this one too), similar condition.  <pending to Brian>
Offers, trades, whatever.
Steve
« Last Edit: July 28, 2017, 09:37:14 AM by dale-j »
Offline dale-j
  • Steve
Re: FS: Split bus odds and ends
« Reply #2 on: July 16, 2017, 01:52:06 PM »
If you have a split but and think you might use this stuff, speak up and bring your pennies before I throw it all out.
Offline dale-j
  • Steve
« Reply #3 on: July 26, 2017, 05:14:49 PM »
9 wire switch pending to Alp.
