Specialty Forums
Bay- curios?
Paper Gaskets?
Topic: Paper Gaskets? (Read 4148 times)
72vwtype2
Phil
Still searching....1972 Single or Double Cab
Paper Gaskets?
December 07, 2016, 09:43:14 PM »
I need to make paper gaskets and glue them on either side of phenolic spacer (i.e. the 1/4 inch rubber spacer that goes between the carb and intake manifold). I will need to make 4 for my dual carb 1.7L bus motor.
Any one know where I can purchase such gasket paper?
Thanks.
1972 Kombi
1964 Vespa 150
BUSDADDY
Re: Paper Gaskets?
December 07, 2016, 10:46:07 PM »
Lordco, Canadian tire, any FLAPS should have it.
72vwtype2
Phil
Re: Paper Gaskets?
December 08, 2016, 10:27:50 AM »
Great Thanks!
My next question is: What is the best glue to use that will allow the paper gasket stick to the rubber spacer and withstand heat and gas?
Thanks.
1972 Kombi
1964 Vespa 150
mitchy965
AirSpeed Forum Member
Re: Paper Gaskets?
December 08, 2016, 11:49:09 AM »
gasgacinch pn#9300 any flaps
bwaz
Re: Paper Gaskets?
December 08, 2016, 12:33:20 PM »
I got my last set from CIP, although I don't see a listing for them...
westcoast-paul
Re: Paper Gaskets?
December 08, 2016, 02:12:20 PM »
T4's came with phenolic spacers on the intake/head gaskets. Do you have that one? It's included in the gasket kit.
if you are jammed - i can look in my stash - i probably have a pair i could give you.
BUSDADDY
Re: Paper Gaskets?
December 08, 2016, 04:27:36 PM »
The spacers between the manifolds and heads are only for FI, for carbs you want the thin aluminum gaskets to transfer as much heat as possible to the manifolds.
bwaz
Re: Paper Gaskets?
Reply #7 on:
December 08, 2016, 09:15:50 PM »
Quote from: mitchy965 on December 08, 2016, 11:49:09 AM
FLAPS?
BUSDADDY
Re: Paper Gaskets?
Reply #8 on:
December 08, 2016, 10:27:06 PM »
F
riendly
L
ocal
A
uto
P
arts
S
tore, although some of the unfriendly ones may carry it as well
72vwtype2
Phil
Re: Paper Gaskets?
Reply #9 on:
December 09, 2016, 08:02:35 PM »
So just to clarify for my stock dual solex carbs. I should only be using the thin aluminum gasket (which I have) with no glue required.
Thanks.
1972 Kombi
1964 Vespa 150
BUSDADDY
Re: Paper Gaskets?
Reply #10 on:
December 09, 2016, 09:36:56 PM »
Thin metal gaskets between the heads and manifolds, phenolic spacers and paper gaskets under the carbs. No glue against any metal parts but glue the paper to the phenolic if you like.
Specialty Forums
Bay- curios?
Paper Gaskets?
