Author Topic: Paper Gaskets?  (Read 17399 times)
Offline 72vwtype2
  • Phil
Paper Gaskets?
« on: December 07, 2016, 09:43:14 PM »
I need to make paper gaskets and glue them on either side of phenolic spacer (i.e. the 1/4 inch rubber spacer that goes between the carb and intake manifold). I will need to make 4 for my dual carb 1.7L bus motor.
Any one know where I can purchase such gasket paper?
Thanks.
1972 Kombi
1964 Vespa 150
Re: Paper Gaskets?
« Reply #1 on: December 07, 2016, 10:46:07 PM »
Lordco, Canadian tire, any FLAPS should have it.
Offline 72vwtype2
  • Phil
Re: Paper Gaskets?
« Reply #2 on: December 08, 2016, 10:27:50 AM »
Great Thanks!
My next question is: What is the best glue to use that will allow the paper gasket stick to the rubber spacer and withstand heat and gas?
Thanks.
1972 Kombi
1964 Vespa 150
Offline mitchy965
Re: Paper Gaskets?
« Reply #3 on: December 08, 2016, 11:49:09 AM »
gasgacinch  pn#9300  any flaps
Re: Paper Gaskets?
« Reply #4 on: December 08, 2016, 12:33:20 PM »
I got my last set from CIP, although I don't see a listing for them...
Offline westcoast-paul
Re: Paper Gaskets?
« Reply #5 on: December 08, 2016, 02:12:20 PM »
T4's came with phenolic spacers on the intake/head gaskets.  Do you have that one?  It's included in the gasket kit.
if you are jammed - i can look in my stash - i probably have a pair i could give you.
Re: Paper Gaskets?
« Reply #6 on: December 08, 2016, 04:27:36 PM »
The spacers between the manifolds and heads are only for FI, for carbs you want the thin aluminum gaskets to transfer as much heat as possible to the manifolds.
Re: Paper Gaskets?
« Reply #7 on: December 08, 2016, 09:15:50 PM »
FLAPS?
Re: Paper Gaskets?
« Reply #8 on: December 08, 2016, 10:27:06 PM »
Friendly Local Auto Parts Store, although some of the unfriendly ones may carry it as well ;)
Offline 72vwtype2
  • Phil
Re: Paper Gaskets?
« Reply #9 on: December 09, 2016, 08:02:35 PM »
So just to clarify for my stock dual solex carbs. I should only be using the thin aluminum gasket (which I have) with no glue required.
Thanks.
1972 Kombi
1964 Vespa 150
Re: Paper Gaskets?
« Reply #10 on: December 09, 2016, 09:36:56 PM »
Thin metal gaskets between the heads and manifolds, phenolic spacers and paper gaskets under the carbs. No glue against any metal parts but glue the paper to the phenolic if you like.
