Author Topic: Scruffy's pan gets a make over..  (Read 18360 times)
Offline getgeoff
  • Geoff
« on: May 14, 2016, 07:26:56 PM »
Well here is the original pan from my 1955 beetle. I am about to start cleaning and seeing if it turns out just as good as spending about 350.00 bucks for sandblasting. There is a great guy in the hood for blasting but he is so busy and I want to get going. I got lots of scotchbrite.
60 11 Window bus Lt grey
55 Wolfsburg Kombi doveblue
55 Beetle ultra maroon
Offline getgeoff
  • Geoff
Re: Scruffy's pan gets a make over..
« Reply #1 on: May 14, 2016, 07:28:37 PM »
Another angle
« Reply #2 on: May 14, 2016, 09:40:33 PM »
cool! i like the multiple thread idea to document the work you're doing to scruffy! have at 'er!!  :cool:
Offline getgeoff
  • Geoff
« Reply #3 on: May 24, 2016, 01:25:51 PM »
Well I ended up dropping off the pan for blasting today. Chris is such a busy guy but he was able to fit me in. It will be getting done while I'm away in Sacro for the bugorama with the Okanagan boys.
Offline Russ
« Reply #4 on: May 24, 2016, 02:20:34 PM »
I think you will be happier after blasting,
I have done ton's of parts people bring be where they spend hours wire wheeling,scotchbrite, and grinding and it's never as clean as sandblasting.
keep us updated
looks like a fun project
Offline mitchy965
« Reply #5 on: May 24, 2016, 05:05:23 PM »
the rust is in the bottom of the pits of the metal ,places where scotchbrite and wire wheels cant get. if you just knock off the top layer the rust is still alive and well, under your new top coat! blasting is still the most cost and time effective method out there. imho
Offline getgeoff
  • Geoff
« Reply #6 on: July 03, 2016, 02:19:49 PM »
Pan back from blaster and waiting for touch ups. Few spots that require a bit of pounding... Some light tapping to make it flat and smooth. Sitting on top of pan is my new RLR chromoly bolt in roll bar.
Offline mitchy965
« Reply #7 on: July 03, 2016, 06:42:15 PM »
 :cool2:
Offline Russ
« Reply #8 on: July 04, 2016, 09:19:06 AM »
looking good man
« Reply #9 on: July 04, 2016, 10:40:10 PM »
roll bar! racer or off roader? :)
Offline getgeoff
  • Geoff
« Reply #10 on: July 05, 2016, 05:53:20 AM »
It will be fast. I hope at least..
Offline getgeoff
  • Geoff
« Reply #11 on: August 04, 2016, 12:04:34 PM »
Welded in a battery tray replacement panel.
Offline getgeoff
  • Geoff
« Reply #12 on: August 04, 2016, 12:06:26 PM »
Built a rotisserie to work on the pan and for ease of painting
Offline getgeoff
  • Geoff
« Reply #13 on: August 04, 2016, 12:07:42 PM »
Frt part
Offline getgeoff
  • Geoff
« Reply #14 on: October 02, 2016, 04:21:06 PM »
Now painted
Offline Schvengy
« Reply #15 on: October 03, 2016, 01:11:49 PM »
 :s_cool:
Offline 72vwtype2
  • Phil
« Reply #16 on: October 04, 2016, 09:10:18 AM »
What paint did you use?
How did you apply it?
It looks good!
1972 Kombi
1964 Vespa 150
Offline getgeoff
  • Geoff
« Reply #17 on: October 15, 2016, 10:40:27 PM »
I used a product called rust bullet. 2 coats of a silver primer followed by 2 coats of the black top coat. You apply with a brush.
