Author Topic: Help! 67 Split wood headliner installation! Anyone have and info!  (Read 2439 times)
Offline Das Bus
Help! 67 Split wood headliner installation!  This is a pain in the ass! how is this done. Any info, pic's, dimensions and tips would be of great help. It seems to not want to fit into the channel, or once in, stay and ridiculous to get in place. the style in this picture is what I'm trying to fit.
      Das Bus.
Offline Brenticon
Re: Help! 67 Split wood headliner installation! Anyone have and info!
« Reply #1 on: February 14, 2016, 06:01:09 PM »
Been having fun myself. Few good links on thesamba, and I also found some by googling
I set one side in jchannel and drooped in center, lined up other edge with j channel, then popped it up into place.
http://www.thesamba.com/vw/forum/viewtopic.php?t=69027
Offline Das Bus
« Reply #2 on: February 14, 2016, 06:57:51 PM »
Ok great I'll check it out because I'm get frustrated man this sucks.
Thank you
      Das Bus.
Offline pittwagen
« Reply #3 on: February 15, 2016, 01:41:44 PM »
Seen this?
http://www.thesamba.com/vw/forum/viewtopic.php?t=304316&postdays=0&postorder=asc&start=0
You are using 3mm baltic birch, right?
When I did the camper interior of my 63 kombi a very long time ago, I used the baltic birch and just screwed it to the edges of the upper rail.  No J channel.  Pushed it up into place, measured it, cut it and held it up in place with 2x4 posts tight to the ceiling.  4 sections. One either side of the vent and 2 rear.
The J channel would be much easier.  I may do that in my current bus if I get the courage to remove the original vinyl headliner.
There is a ton of info on the samba.  Just look for it.
Offline Das Bus
« Reply #4 on: February 15, 2016, 01:48:54 PM »
Ok great thanks
I'll look when I get home.
Cheers!
      Das Bus.
