Air Speed Lounge
Bulkhead
Topic: Bulkhead (Read 2245 times)
gsun
AirSpeed Forum Member
Bulkhead
February 11, 2016, 06:14:34 PM »
I need to get the gas tank bulkhead out and it doesn't want to budge. It is under clips at the top and the bottom seems to be folded over. Anybody know how to get the bugger out? It has the gas heater section that did come out. 1970 bus.
9 years and counting....
BUSDADDY
Re: Bulkhead
February 11, 2016, 06:21:46 PM »
There's 4 screws up from below that have to come out, 2 each side of the transmission near the edges of the cover buried under grease. If all those as well as the obvious ones in the engine compartment are out then it's just the gasket holding it.
gsun
Re: Bulkhead
February 11, 2016, 08:34:43 PM »
Took the ones out in the engine compartment. Will crawl under to see about the rest. All the books say is "take the bulkhead out". Thanks!
Air Speed Lounge
Bulkhead
