Author Topic: need some Help 67 vw bus rear upper cabinet installation instructions?  (Read 2212 times)
Offline Das Bus
Hi
Can anyone tell me how the upper rear cabinets on a 67 split window camper are fastened anyone have any info, measurements of cabinets or pics  I'm making my own. But was wonder how they were normally mounted? any tips tricks or picks on how they're done factory? eg like this one in the picture?
thanks Jerry
      Das Bus.
Offline pittwagen
Re: need some Help 67 vw bus rear upper cabinet installation instructions?
« Reply #1 on: January 29, 2016, 06:12:21 PM »
You need to make 4 L brackets and screw them into the upper channel area with the L hanging down and then bolt or screw them to the bottom of the cabinet.  Page 33 of the Bay Window Bentley manual sort of shows the bracket on the early bay camper.  Done right you should be able to mount the brackets and then slide the cabinet rearward into place.  I only had to do 2 on my 79 as I had the side closet on the left side.  Here is a page from the late bay westfalia repair manual showing the bracket:
http://www.thesamba.com/vw/archives/manuals/1978westymanual/16.jpg
Seen this?  66 Campmobile upper cabinet.
http://www.thesamba.com/vw/archives/manuals/66campmobile_partslist/illustration3.jpg
« Last Edit: January 29, 2016, 08:16:42 PM by pittwagen »
Offline pittwagen
« Reply #2 on: January 29, 2016, 08:15:25 PM »
Here is a pic of the Westfalia P21 right side brackets:
Offline Das Bus
« Reply #3 on: January 29, 2016, 08:29:58 PM »
Great thanks man!
jerry
      Das Bus.
