Technical
Engine Tech Forum
Suggestions on a good functional breather box
Topic: Suggestions on a good functional breather box (Read 5762 times)
s3racing
August 10, 2015, 11:28:52 AM »
Breather Box for engine crankcase and valve cover venting. Here is a picture of a unit from CIP are they any good. Or can anyone suggest a good one to use for my Car. Efi 2387cc engine if it maters.
Thanks for any tips
Rene
http://www.airspeedparts.com/forums/index.php?topic=649.msg5665#msg5665
http://www.airspeedparts.com/forums/index.php?topic=22527.0
The hardest part of chasing your dreams is not ever letting them go!
neil68
Re: Suggestions on a good functional breather box
August 10, 2015, 01:13:57 PM »
I have a slightly used CSP 6-outlet stainless steel polished breather box for sale for $25. I can bring it to the GCVWS weekend: CIP1.ca part #C31-115-451-180.
Neil
Der Kleiner Rennwagens
'68 Beetle 2332 cc
12.6 sec at 109 mph
s3racing
August 10, 2015, 01:37:00 PM »
Neil,
Are the outlets / inlets threaded or barbed ends for a hose. Ideally it would have -8AN or -10AN or threaded so I could add AN fittings to it.
Otherwise looks like a good setup! Why are you selling it or not using it if I may ask?
Thanks Neil
neil68
August 10, 2015, 04:14:35 PM »
They're 1/2" tube fittings...no threads:
https://www.cip1.ca/ProductDetails.asp?ProductCode=C31%2D115%2D451%2D180
I changed my fuel lines, so I had to remove the CSP box from the firewall as it was in the way. I'm using my old Latest Rage tower breather for now.
Last Edit: August 10, 2015, 07:26:30 PM by neil68
Neil
'68 Beetle 2332 cc
12.6 sec at 109 mph
Technical
Engine Tech Forum
