Author Topic: Drag racing at the Great Canadian weekend on Friday night.  (Read 5276 times)
Offline getgeoff
  • Geoff
« on: August 03, 2015, 09:02:20 AM »
Do you have to have seat belts in your car in order to race on the Friday night? My vw beetle is older and never came with them from the factory. So what are the rules to be able to participate.
60 11 Window bus Lt grey
55 Wolfsburg Kombi doveblue
55 Beetle ultra maroon
Re: Drag racing at the Great Canadian weekend on Friday night.
« Reply #1 on: August 03, 2015, 09:43:33 AM »
Basic tech rules and regulations:
* All cars must have seat belts.
* All cars require a 16oz or larger radiator overflow can.
* All vehicles must drain antifreeze prior to racing (except 1995 or newer stock car and trucks with sealed factory coolant system). Bring a plastic container.
* No plastic or glass fuel filters allowed.
* No plastic oil pressure lines allowed.
* Vehicle windshield must be free of cracks
* All vehicles must have a functional neutral safety switch.
* All batteries must be securely mounted (no bungee cords, rope, wire etc) Batteries may not be relocated into the driver or passenger compartment. Rear firewall mandatory when relocated battery in trunk. If sealed battery box is used, must be vented outside of body. When battery is relocated a master power cut off switch must be installed on rear most part of vehicle.
* The trunk and passenger compartment of the vehicle must be empty prior to racing and all stereo amplifiers and speakers must be securely mounted.
* Drivers must wear full length pants and shirt (no shorts, muscle shirts, tank tops, open toe sandals or clothing made of nylon type material allowed) T shirts OK.
* Drivers of cars running 13.99 or quicker are required to wear an NHRA approved Snell 2005 or newer helmet (Note: As of January 1, 2007 the Snell 95 helmet will no longer be legal to use at NHRA / MRP race events). Passengers are allowed in vehicles running 14.00 seconds and slower provided they wear their seatbelt and a Snell approved helmet. All drivers of convertibles regardless of ET must wear a Snell approved helmet.
* A drive shaft loop is required on all cars running on racing slicks. Not required on cars running 11.49 and slower ET’s on street tires.
* Cars running 11.49 or quicker ET’s (and all convertibles running 13.49 and quicker) must have an NHRA approved roll bar, SFI approved seat belts & jacket.(frame connectors and wheel tubs OK). All cars equipped with a standard transmission running 11.49 and quicker must have an SFI approved bellhousing, flywheel and clutch.
* Cars running 10.99 or quicker ET’s must have approved aftermarket axles, harmonic balancer and transmission shield meeting spec. 4.1. Any car running 10.99 or quicker ET’s that has had major alterations to the firewall and/or floor plan and/or any car exceeding 135 MPH (regardless of ET) must also have an NHRA approved roll cage and window net.
* Cars running 9.99 or quicker ET’s must have an NHRA approved roll cage and certified chassis, SFI approved flex plate, transmission shield, window net, andmaster cut off switch. NHRA Competition License, SFI approved 3.2 A/5 race jacket, pants and 3.3/1 gloves and neck collar.
* Regarding Nitrous Oxide (NO2) – The use of Nitrous Oxide is allowed in all Street Legal classes provided that any Nitrous bottle located in the drivers compartment be equipped with a pressure relief valve and vented to the outside of the vehicle. All Nitrous bottles must be securely mounted (plastic mountingbrackets not allowed), be stamped with and meet the minimum DOT 1800 PSI rating and be clearly identified as Nitrous Oxide
* Regarding Motorcycles – All bikes must be registered and insured for street use. All drivers are required to wear a full face helmet meeting the minimum Snell 2005 or SFI 31.1 specifications. Leather jackets, leather boots / shoes (shoes must extend above ankle) and leather gloves are mandatory for all motorcycle drivers. Full leathers or SFI spec 40.1/2 race suit mandatory for all riders of motorcycles running 120 MPH or faster (regardless of ET). NHRA Competition Licence required for drivers of motorcycles running 9.99 or quicker ET’s. All motorcycles must be equipped with a positive ignition cut-off (factory kill switch permitted) switch attached to the driver with a lanyard. Wheelie Bars not permitted.
* All vehicles must be capable of meeting the NHRA safety requirements according to the vehicles ET and MPH capability (for further information regarding Safety Requirements please refer to the 2013 NHRA Rule Book – available at most high performance automotive shops throughout Greater Vancouver and Fraser Valley).
Offline getgeoff
  • Geoff
« Reply #2 on: August 03, 2015, 10:55:53 AM »
I was just going to go into the stock motor challenge with my 40 hp engine. Too much rules for a stocker that's 55 years old and it's a challenge just to get it up to speed on the Coquihalla hwy. lol.
Offline getgeoff
  • Geoff
« Reply #3 on: August 03, 2015, 11:06:38 AM »
Thanks for the rules Chris..
« Reply #4 on: August 03, 2015, 11:34:02 AM »
you are going to just need this most of wich is comon sence items.
thanks chris for getting list up,see you out there i hope
* All vehicles must have a functional neutral safety switch.------( never came with it not a problem )
* All batteries must be securely mounted (no bungee cords, rope, wire etc) Batteries may not be relocated into the driver or passenger compartment. Rear firewall mandatory when relocated battery in trunk. If sealed battery box is used, must be vented outside of body. When battery is relocated a master power cut off switch must be installed on rear most part of vehicle.----( if battery is in stk location and clamped down its ok as original location has not changed , but need correct mounting no rope ect )
* Drivers of cars running 13.99 or quicker are required to wear an NHRA approved Snell 2005 or newer helmet (Note: As of January 1, 2007 the Snell 95 helmet will no longer be legal to use at NHRA / MRP race events). Passengers are allowed in vehicles running 14.00 seconds and slower provided they wear their seatbelt and a Snell approved helmet. All drivers of convertibles regardless of ET must wear a Snell approved helmet.---( if you have a strong tailwind)
« Reply #5 on: August 03, 2015, 10:48:28 PM »
imho, it is always best to put safety first, follow all the rules and have a properly maintained machine! :cool:
to add to that, my past experience with the SMC and mission raceway has been this...when you tell the person thats doing the tech inspection that you have a bone stock engine and you hope to run a 19 or 20 second pass, they won't open your decklid to looks for fuel filters and they won't pull up your back seat to see the battery hold down. they really dont pay much attention to the car (unless it has an open cockpit or stands out in some other way, like having cracked glass or parts falling off, ect) and usually just wave you through...they've got other cars to deal with that are more difficult to tech.
so geoff...it sounds like you would be ok if you had seat belts. if there is any way you can make that happen (an understandably significant hurdle at this stage of the game, but could be possible ;)), you know we'd love to have you participate in the SMC! it's going to be a blast!! :cool:
« Reply #6 on: August 04, 2015, 12:01:31 AM »
Velcro should suffice geoff!
Offline getgeoff
  • Geoff
« Reply #7 on: August 04, 2015, 11:38:10 PM »
I'm on the fence for drilling holes into the old bug.... Will see..
