Air Speed Lounge
RCA CABLES TO THE REAR OF NON WALK THROUGH VW SPLIT BUS? Where?
Topic: RCA CABLES TO THE REAR OF NON WALK THROUGH VW SPLIT BUS? Where? (Read 2072 times)
Das Bus
AirSpeed Forum Member
May 04, 2015, 03:48:09 PM »
Where is everyone with amps in their split Window bus
non walk through running there RCA cables to through to the rear?
Das Bus.
Alp
I’m not your type. I’m not inflatable.
Re: RCA CABLES TO THE REAR OF NON WALK THROUGH VW SPLIT BUS? Where?
May 05, 2015, 04:38:10 PM »
why have the RCA's going to the back of the bus? Why not have the amp close to the head unit and speaker wires only going to the back?
rekka
May 05, 2015, 08:08:07 PM »
Yeah, I bolted my amp to the bulkhead, behind the passenger seat. Next project is a sub box shaped like a spare wheel.
Radwerx. Architectural features in wood, metal and concrete
www.radwerx.ca
Das Bus
May 09, 2015, 08:21:48 AM »
ya i was thinking about the bulk mounted amps two they should fit there and just run the wires for there. The whole system is off amps so there is three sets so its a ton of rca to run. thanks for the input guys!
Das Bus.
Air Speed Lounge
