Author Topic: Brake Hub adaptors and calliper Brakets  (Read 14083 times)
Offline s3racing
« on: October 29, 2014, 11:30:42 AM »
Is there anyone local. In Van that does special machine work.
 What i'm after is someone that can machine spindles, and Brake hubs so that they work with each other. What I want to do is have a set of Boxster Hubs machined to fit Beetle Wheel Bearings so i can mount them onto my CB drop spindles. And then Fabricate Calliper mounts. on the rear I plan on using 944 Disc's and Boxster Callipers, so just need Brackets Fabricated and a way to solve the E-brake cable problems. Is there anyone local that I can turn to for Help with this. I know its doable.
Thanks for any pointers.
René
Offline notorious B.U.G.
Re: Brake Hub adaptors and calliper Brakets
« Reply #1 on: October 29, 2014, 05:42:15 PM »
Not local but Canadian (Ontario)
http://vdubengineering.com
Lanner probably knows exactly what you require to fit your brake system.
Like machining the hubs correctly. It is usually better to pay a bit more so it is done right the first time.
56 Patina Sedan
Offline s3racing
« Reply #2 on: December 15, 2014, 11:46:07 AM »
Any other options other than Lanner. He just moved this summer to Alberta. I ordered a front and rear set up from him but think I might have to find other options. As I already have the Calipers disc's pads wheels etc. So I need to stick to the boxster/944 hub set up. Unfortunatly Lanner doesn't seem to have time to work on my brake set up.
« Last Edit: December 15, 2014, 12:02:15 PM by s3racing »
« Reply #3 on: December 15, 2014, 01:31:35 PM »
http://amtmachineshop.com/
Great guy, and he can do what you need.
Offline s3racing
« Reply #4 on: December 23, 2014, 02:46:03 AM »
Thanks Dave,
I dropped him a mail said he'd have time for me in the new year! Getting my brother then to contact him and arrange the details of the conversion.
Offline s3racing
« Reply #5 on: February 11, 2015, 03:46:36 AM »
Adam ended up doing the conversion parts for me. From the pictures it looks like clean work. It is custom work but did cost more than I expected. With that said he was easy to work with patient and when he had everything got it done quite quickly. So I would recommend his work and if need be use his services again for parts fabrication. If it works out here when I have the car imported I might do a series of the same kit to sell local. But that's still a ways away:-)
All in all Adam did a great job and would totally recommend him!
