Author Topic: Engine turns over but doesn't fire up  (Read 6345 times)
Offline Drew604
  • 68 project bug
« on: October 09, 2014, 02:14:29 PM »
I have a 68 bug with the 1500cc
I have rebuilt the carb,new fuel pump, new plugs and wires, new coil and it's getting spark but just won't fire up unless I hit the carb with carb cleaner but then it dies right after that. Would anybody have any suggestions on what else I could try? Any help is greatly appreciated!
Drew
68 project bug
Re: Engine turns over but doesn't fire up
« Reply #1 on: October 09, 2014, 03:13:34 PM »
Assuming you put gas in the tank are you sure the inlet and outlet lines on the fuel pump are correct?, newer pumps are in on the top and out on the bottom.
Offline Drew604
  • 68 project bug
« Reply #2 on: October 09, 2014, 03:39:34 PM »
I'm getting gas into the bowl in the carb
68 project bug
« Reply #3 on: October 09, 2014, 05:10:45 PM »
Then try putting your hand on the throat of the carb while someone cranks, it'll feel weird but it won't suck your hand off or injure you, sometimes that unsticks things that are plugged from sitting.
Offline scubagord
  • The Cabinet Guy
  • Another VW fanatic
« Reply #4 on: October 09, 2014, 09:21:11 PM »
Check the fuel shutoff solenoid.
65 sunroof beetle
56  Single cab original paint
68 Single Cab
Offline Cameron
« Reply #5 on: October 09, 2014, 11:20:07 PM »
Double check your spark plug wire firing order. Make sure each wire is going to the correct plug.
