Author Topic: Trans Gears?  (Read 5849 times)
Offline lizard
Trans Gears?
« on: July 13, 2004, 09:49:25 PM »
What ser# do i go after to find what gearing is in my Trans ( 5rib)
 will it tell the r/P ratio also?
Also what is the lowest first gear that u can buy for the above trans?
 whats the lowest R/P ? 5:37??
 Can u run on the street with a spool?? anyone doing it?
 Is there a reverse switch like the swingaxle trans on these trannys? cuz I dont see it :blink:
any links would be helpful also.
Trans Gears?
« Reply #1 on: July 14, 2004, 07:25:11 AM »
http://fly.hiwaay.net/~jfrohwei/vwac/tables.html
thats all i have,mabey someone else can help??
russ
Offline Scratchy
Trans Gears?
« Reply #2 on: July 14, 2004, 10:36:29 AM »
Not sure what tranny you have but here are a few links I found while scoping out a Type 2 tranny for the Ghia:
http://www.syncro.org/FinalDriveRatios.htm
http://www.bugtrans.com/transaxles1.html
http://www.justveedubs.com/transcodes.htm
http://davewin.com/tech/gear_ratios.shtml
Just to get you started....  :rolleyes:
« Last Edit: July 14, 2004, 10:40:17 AM by Scratchy »
Offline lizard
Trans Gears?
« Reply #3 on: July 14, 2004, 03:57:46 PM »
one of those were pretty good, But my trans is out of a bus an most of that is for the beetles or golfs
Trans Gears?
« Reply #4 on: July 14, 2004, 07:39:59 PM »
i run the street with a spool,,,, :D
