Author Topic: Noisy Fuel Pump  (Read 5042 times)
Offline KOOL-AID MAN
Noisy Fuel Pump
« on: July 12, 2004, 11:04:47 PM »
my bug has an electric fuel pump that makes a high frequency ticking sound when i turn the ignition, is this normal, it kinda sounds like a little compressor??? it werks good, and you cant here it when the engine is running, but that would be because of the stinger, im sure it still makes that sound tho :)
Noisy Fuel Pump
« Reply #1 on: July 16, 2004, 06:35:05 AM »
THey all sound like that ... No Worries... Just never leave the ignition on with out strating your car..
Noisy Fuel Pump
« Reply #2 on: July 16, 2004, 10:07:41 AM »
Also where is it located, pumps like to push not pull the fuel so if it is located in the rear of the car it will work harder and sound louder.
My pump is located up front under the tank (passenger side) I made an aluminum mount that has rubber grommets both under the pump to the mount and under the mout to the car. Only time I hear it is if my system needs to be primed.
Noisy Fuel Pump
« Reply #3 on: July 17, 2004, 03:09:02 PM »
yeah mine is located above the transmission, so i guess shes werking pretty hard, maybe i'll move it but it looks like its been there a long long time, haha thanx guys  :rockon:
Offline Needles
Noisy Fuel Pump
« Reply #4 on: July 17, 2004, 04:43:31 PM »
Damn, Kool-aid is great on a 30 degree + day!! B)
Noisy Fuel Pump
« Reply #5 on: July 19, 2004, 10:03:07 PM »
hahahaha, f'in rights it is
