Author Topic: 56 deluxe oval - the project is getting close to road.  (Read 37535 times)
Offline J A Red
« on: May 01, 2014, 02:52:55 PM »
Thought I'd post the beginning of my first ACVW project.
I got the body off the pan right away and started inventory of what was missing and what need to be replaced. Ended up ordering all new bearings and seals for the 4 corners as well as all new brake parts for the rear. The PO had already done the front brakes. I installed drop spindles last month and dropped the rear 1 spline as well.
The big change was selling that really nice 36hp engine that I picked up from Thomas a couple months back. I picked up another engine yesterday and couldn't wait to see what it looked like bolted up to the pan.
I'll post more as I progress.
« Last Edit: July 15, 2016, 10:09:35 PM by Reed Green »
‘59 Light Green Double Cab
Sherbet Orange Meyers Manx
Re: 56 deluxe oval - the project begins
« Reply #1 on: May 11, 2014, 08:56:04 AM »
Right on man, looks like a good start to a killer oval! More pics!
Offline J A Red
« Reply #2 on: July 27, 2014, 10:55:04 AM »
Had some parts painted by Slammedbus and picked them up on Friday. All original colours and super happy the way they turned out. Now just need some tires and I'll have a complete rolling chassis.
Offline Kevin K
« Reply #3 on: July 28, 2014, 09:21:22 PM »
very cool
paint looks awesome, love the original colours
good to see progress
1960 bug
Offline J A Red
« Reply #4 on: December 21, 2014, 01:45:41 PM »
Haven't had a chance to do much, but thought I'd post a few pics.  This past week I've been mocking up the engine to install the Fram oil filter, and replace the throttle with the original style from WW. Should have the oil lines and oil cooler delivered early January, the all the engine tin will be sent out for blasting and powder coating.
Offline Kevin K
« Reply #5 on: December 22, 2014, 01:00:50 AM »
looks good
i love that fuel line
just wondering if you got that as a kit or if you got the line and fittings yourself, thinking of doing something similar on my car
thanks
1960 bug
« Reply #6 on: December 22, 2014, 07:08:12 AM »
The fuel line is part of the ww okrasa kit.
Also if possible toss the engine into the car and check clearances on the engine lid spring and the fram filter, it was TIGHT up there in the split, but that was also a large spring car so ya never know.
Offline J A Red
« Reply #7 on: December 22, 2014, 05:20:03 PM »
Yeah, fuel lines come with the kit. Joe Ruiz (Mr Okrasa) sells them separately if you are looking for some. I'll be doing the final fitting and install once the media blasting is done with it in the car.
« Reply #8 on: January 11, 2015, 10:01:30 PM »
the projects forum here on the asf is cooking with some sweet rides...and this 56 oval is one of them!
great work reed green, gotta love an oval and that engine rocks! keep plugging away at it!
Offline J A Red
« Reply #9 on: April 14, 2015, 10:44:29 PM »
Been a little slow on the project front, until today. Got the body loaded on Gordo's flat deck and dropped it off paint. Thx Gordo!
Should have it back early May all shiny and green.  Might just be driving this year?!
Offline Thomas
« Reply #10 on: May 18, 2015, 11:40:22 AM »
Paint pictures?
Offline J A Red
« Reply #11 on: May 18, 2015, 02:42:01 PM »
No paint yet. Ran into a couple minor issues but should have the car back home first week of June. Will have a bunch of pictures and updates then.
Offline J A Red
« Reply #12 on: July 17, 2015, 08:32:13 PM »
Time for an update.
So the body has been in the paint shop since April now, and we are finally getting close to seeing some colour on it. Ran into a number unforeseen issues with the body and pan that either needed to be fixed or that I couldn't leave be.
First discovered some minor corrosion under the primer randomly around the body. Looked like after the PO stripped it down to bare metal, that it was not wiped down properly prior to priming. So off came all the old primer and back to bare metal she went.
Second issue came up by fluke really when one of the driver's door hinges was being replaced. I brought the pan into the shop so the body could get bolted down tight and help line up the door and new hinge. (Keep in mind I bought this car with the body just sitting on the pan and had never bolted it up myself) Upon trying to bolt the body down it became evident that the pan had a twist in it somewhere. So I get the phone call to come down to the shop to check out the twist. So off comes the body and there we are measuring the pan to find out why it's twisted. PO told me that he had replaced the pan halves, and that's where the problem turned up. Turns out a less than perfect weld holding the rear of the left pan had let go creating a twist. Soon as that section was clamped tight, bingo everything straightened out. But now that we started looking at the weld job we found a bunch more little things that "probably" should get fixed.
So with a now straight pan and the body bolted down, it's on again. Door hinge gets replaced. Now Kelly (the body guy) decides to bolt all the fenders and hood and lid to check for fitment. And another phone call to come down to the shop. Something was out of whack in the front apron area. shit!!! Here we go again. Back when the body was taken back down to bare metal, a number of small patches here and there were found, they looked fairly well done at the time, but with the body sitting square and flat on the pan nothing was lining up. It was all closed but not great. It seems that the PO didn't square anthing up before welding in any of his patches. Soooo, out come the patches and replaced once everything is squared up. This included the front apron, the hood, all four fenders and rear body mounts. Now with all the doors, fenders, hood and engine lid fitting just right, it's time to get back to why the car is there. PAINT. So although the car's been in the shop much longer than expected, I'm super happy with the job being done.
Offline J A Red
« Reply #13 on: July 17, 2015, 08:35:37 PM »
A couple more pics of the body work.
Offline Thomas
« Reply #14 on: July 18, 2015, 05:23:54 AM »
Looking great! What colour are you going with?
Offline J A Red
« Reply #15 on: July 18, 2015, 01:23:15 PM »
Thanks Thomas, going with original Reed Green, which was only available for just less than a year.
Should look like this
« Reply #16 on: July 22, 2015, 11:09:21 AM »
so awesome!  Keep up the good work!
« Reply #17 on: July 22, 2015, 10:45:37 PM »
body work is looking good! keep at 'er reed green!!  :cool:
Offline J A Red
« Reply #18 on: July 29, 2015, 10:38:29 AM »
A couple weeks ago while the pan was still at the body shop I decided I had time to deal with my gas tank and get it ready to install once the body and paint were done. I'd had it media blasted and painted last year, but wanted to get the inside sealed. After some research if found that POR 15 makes a kit, so off I went to Lordco. My buddy that works there was able to supply me with the three components of the kit (cleaner, metal prep, and sealer) separately at a better price. I was hesitating on getting the cleaner because the PO had the tank stripped and cleaned a number of years ago.....shouldn't be anything in there right? shining a light inside showed a nice clean tank with minimal surface rust. shaking the tank turned up some hidden blasting sand. Ah, what the hell, cleaning it again won't hurt. Followed the directions, and mixed it at 1:1 with hot water and poured it in. Then spent the next couple hours rotating the tank to let the cleaner do its job.......and look what came out when I drained it! must've been stuck on real good!
Offline J A Red
« Reply #19 on: August 19, 2015, 06:51:30 PM »
A pre-GCVWS update. 2 weeks ago the painter called to say that his supplier couldn't locate the formula for L313 in a single stage. After some emails and texts with no luck, I thought what if I just google it? sure enough first hit was the Glasurit formula for single stage. So now car is primed and zipped down today to see the first bit of colour on the car.
« Reply #20 on: August 20, 2015, 08:07:54 AM »
Was thst a squirrel in your tank? Hahaha good one!! Car is looking good, keep at it!!!
Offline Russ
« Reply #21 on: August 20, 2015, 10:14:48 AM »
I love seeing colour for the first time
Offline J A Red
« Reply #22 on: August 25, 2015, 10:47:22 PM »
Big day today! Went down to the body shop and brought home the Oval.
Offline J A Red
« Reply #23 on: August 25, 2015, 10:55:24 PM »
Heading camping for a couple days, but could resist getting to work on the oval right away. doors are hung and fenders have been temporarily mounted so the body can be polished.
Offline Thomas
« Reply #24 on: August 27, 2015, 08:50:05 AM »
Looks great. Love the colour.
« Reply #25 on: August 27, 2015, 03:29:53 PM »
Oh I remember this stage! Can't help yourself but to start bolting stuff on! Looks great man and was good meeting you at the show.
Offline J A Red
« Reply #26 on: May 02, 2016, 11:45:23 AM »
So it's been a while, so thought I'd post a couple overdue updates and pictures.
Last fall the a bunch of Okanagan members decided to do a cruise, so I had them drive by and help lift the body onto the pan. Wow, great to see the body and pan back together. And was great to have everyone swing by to help out.
Offline J A Red
« Reply #27 on: May 02, 2016, 11:51:22 AM »
After getting the body on the pan, I put the fenders on and it sat for most of the winter with no time to work on it.
Offline J A Red
« Reply #28 on: May 02, 2016, 11:56:15 AM »
April finally brought some time to work on the Oval, so I started of with getting the engine installed. Wasn't sure how hard that was going so jacked the back of the car and jumped right to it. Less than an hour later it was in! Think it looks pretty cool
Offline J A Red
« Reply #29 on: July 15, 2016, 09:59:36 PM »
Well the project is getting close being driveable, so thought I'd take some pics and show the progress.
- wiring is done and all 6volt electrics are working except horn and interior light.
- sound deadening done.
- All windows are in and doors are all trimmed out.
- new Flat4 GTV steering wheel installed. Shortened the steering column to make up for the deeper dished wheel.
- all trim and emblems
