Author Topic: Tranny code  (Read 10920 times)
Offline Big Shaver
Tranny code
« on: April 08, 2014, 08:28:25 AM »
I have a tranny from a 71 Standard Beetle with the code of AY 23 10 2. I cannot find technical information on the internet about this AY code. Any help?
On closer examination it appears that  the original factory stamp has been ground down and a AY was hand stamped. Did VW have a rebuild program for transmissions like they did for engines?
« Last Edit: April 08, 2014, 09:31:09 AM by Big Shaver »
Offline scubagord
  • The Cabinet Guy
  • Another VW fanatic
Re: Tranny code
« Reply #1 on: April 08, 2014, 09:18:37 AM »
I don't know about the "AY" part. you might want to check that code out closer. Here is a link to a tranny code site.
http://www.shining-wit.net/rick/buggy/design/transmission/#Understanding Transaxle Codes
Good Luck
Gordo!
65 sunroof beetle
56  Single cab original paint
68 Single Cab
Offline pittwagen
Re: Tranny code
« Reply #2 on: April 08, 2014, 02:58:55 PM »
You won't find any info on the AY trans.  I have looked for months and found nothing.  Even Bruce T.  was baffled.  Nothing out of the ordinary about the trans.  4.12  R&P and not much else.
Offline Big Shaver
Re: Tranny code
« Reply #3 on: April 09, 2014, 08:37:49 AM »
OK thanks for the information!
Re: Tranny code
« Reply #4 on: April 21, 2014, 06:38:57 PM »
I have seen that code before.  I just don't remember what the internal config was when I had one open.
Offline pittwagen
Re: Tranny code
« Reply #5 on: April 21, 2014, 08:02:50 PM »
Ah, the mists of time have clouded the memory.
Steve R. recently pulled the one (AY code) apart I was telling you about a few months ago.  4.12 r&p and nothing special so it was tossed.  They had a couple spares already.
I would have been interested if it was a 3.88 or 4.37.  I have an IRS with a similar configuration so if I need a swing I can put the swing super diff in that I have and go from there.
