more stuff added and more on the way
Ill keep adding and updating this as we go...Header for 13-1600cc good used $25
Header and dual QP very few miles on it, great shape $75
Sold AlH15" bus wheels blasted, powdercoated off white by Russ, new hub cap clips and two nos bias tires and two used 600-15 bias four new tubes mounted $600
sold without caps shown.
Two misc new inter coolers $30 ea
one sold NOS VOlkswagen 40 hp bus fresh air muffler $100
15" bus wide 5 wheels set of four $200 or $60 ea
Bay window sunroof cables, sliders, guides and all hardware $300 mint condition.
sold to GreggTwo speed defroster air box, beetle $50
Pre 57 coarse spline steering shaft and colum $60
Oval colum tube $25
60 up colum $20
Pair t34 tail lights $150
SOLDT34 windsheild, has long scratch but otherwise very nice $300
Orig VW baywindow tow hitch $100
sold westy69*******
Porsche 911-944 front seat, 4 way power on drivers $150 pairs
SOLDsorry just one pic of drivers, pass is better.
55-60 split bus rear apron, crank start in dive blue with patina $200
sold to johnUsed 36 hp head $40
Puma fan shroud kit with rear tin. This is for dog house cooler and fresh air heat, gives lots of clearance for raised eng it tight engine bays $175
New vw dog house fan shroud, vw of Mexico $50
New in the box rear 4 bolt beetle/ghia drums $10 ea
56-64 window regulators new $10 ea I think there is 20 total?
Pair of 15x8 white spoke wheels $50
soldNew west coast metric front window trim 73-79 vert beetle $20
Nos t1 rear apron fits 75 with carb engine $75
FI beetle engine case, 8mm inserts, fresh line bore and thrust cut std bore 85.5 Perfect for building high performance engine. $200
SOLDPair of wheel adapters, wide 5 to 4 bolt VW $30
Two split bus westfalia so42 windows $350pr
64-67 bus front drums and backing plates with all brakes , drums are at max allowable $50
T4 weber progressive carb and manifold kit $100
T1 Weber Progressive kit $125
NEW KYB Gas a just ball joint shocks for baja or raised suspension. 17.5 compressed and 22.5 open $50pr
Sold AlHNOS VW wiper motors can work on beetle,rabbit Golf etc retail over $100ea I have a bunch $10 ea
Custom muffler fits small 3 bolt header,it's only been run a few mikes. Great to modify for your own project $30
SoldAccesory spot light mirror, clamps to gutter ot door jam $125
SOLDparts below added April 2Custom flo-pro exhaust for beetle fits merge header, ceramic coated $125
Pair of CB dellorto rain hats/ turbo hats $50
Drivers IRS beetle control arm free
443-422-065-cox rebuilt steering rack for Audi new was $500.... $75
CB spin on filter mount and oil pump, barely used $ 50
New Erco IRS heavy duty billet side cover for T1 trans $100
Rhino race transmission case $150
Pair of 911 heater boxes from a 83, fits many years $100 pair
Two original EMPI sprint star chrome 4 bolt wheels. 5.5 wide. Deep dish, all orig decals are inside rim still. One has some chrome peeling but still very good $150 pair
Bus front spare tire mount $20
New CB performance deep sump for T4, a must on a high revving T4 $100
Very nice single turtle back rim $60
One single orig painted silver EMPI sprint star 4 bolt 5.5 wide $75
Two automatic starters great for high perf engines $50 ea
Two Uniroyal Laredo 195-75-r14 m+s tires 90% tread $60 pr great for bus
Sold. kinggeorge13
