Author Topic: Air Biscut And Speed E  (Read 6065 times)
« on: August 23, 2003, 01:38:28 PM »
We just spent the morning removing the aprons and spare tire are from the \"Air Biscut\". We then hooked it up to the winch and made a few pulls to bring the nose back into shape. All is looking good with the alignment of the hood and fenders.
The Speed E Delivery van will be back to the shop today so i can start going on all the body work and everything else it needs.  NEW PIC's Added
Here is a shot of the bus after some rust removal
Here is the lower drivers rocker, The previous owner had someone do bodywork on the bus (this guy is in Surry watch out!) The new rocker was glued and welded over the old one without removing the rust! Nice Job!
Here you can see i have pulled the rocker off to find how bad the rust is, You can see the frame is still perfect as is the outriggers and frame supports.
Here you can see the \"repair\" that was done on the rear 1/4 - fender. If you look closely you can see the spot welds where  the panel was attached.
This is what was under it!!!!! not much, looks like i'll be doing a little work here.
« Last Edit: August 25, 2003, 09:33:05 AM by Gkafer »
Offline 1969deluxebus
« Reply #1 on: August 23, 2003, 06:09:26 PM »
They are for sure going to be sick rides  the bus will be so fly good luck on going it all have don't for get to have lots of fun  :rockon:
matt :mullet:
Offline Project Decade
« Reply #2 on: August 23, 2003, 08:54:56 PM »
Hey Geoff when do you think the SPEED E DELIVERY VAN will be done and on the road? Will you deliver parts right to my door yayaya can't wait to see both projects on the road sometime very soon good luck  :D
« Reply #3 on: August 24, 2003, 07:26:42 PM »
I'm going to be workin on the bus as much as i can. Spent 5 hrs on it today. Removing all the \"Body Work\" the previous owner had done. Wait till ya see the pics of the rust that was covered up! I got a lot o work ahead of me.
« Reply #4 on: August 25, 2003, 09:44:14 AM »
update!
Offline bajabarbie
« Reply #5 on: August 25, 2003, 10:53:41 AM »
heehee...keep drinking there matt.....keep...drinking...... :blink:  :D  :P
« Reply #6 on: August 25, 2003, 11:06:45 AM »
Good lord thats some fine craftsmanship there....that guy musta been proud when he was done! Gives the trade a bad name though :angry:
« Reply #7 on: August 26, 2003, 08:58:56 AM »
Here are a few pics of the biscut with the nose repair started.
Here she is before we removed the apron, As you can see it was hit hard enough that the pass front 1/4 has a large crease and is kinked. The nose was pushed back about 1.5 inches.
Here you can see some of the wrinkles in the inner fender
Here the spot welds have been drilled out and the apron removed, lots o rust in the spare tire well. We will replace the apron and lower well area.
Here you can see that we used a home made puller, dont laugh it worked. We straped down the body and used the winch to pull the nose as we hammer and dollied the kinks out. The end result was better than we thought and all fenders and hood lined up nice!
More pics to come.
« Reply #8 on: August 26, 2003, 09:43:14 AM »
Here are a few more shots of  Speed E, Spent last night doing a little paint and rust removal.  The pic below shows using a flat razor blade to remove the old paint. This paint job looks to be the second that has been done or so it appears. The van was primered at one time in a brown color and then there looks to be a green metalic? maybe it was used as a guide coat? The Neptune blue was then applied over the green.
The flat blade while it remains sharp is a great way to remove the old paint. It's a little soar on the fingers but makes quick work of it.
This is aprox 1 hr later, my fingers are raw and i'm only half way thru the center of the roof.
Next i moved onto drilling out the spot welds on the inner rocker. To get at these i'm drilling down from inside the cargo area. the holes will be filled with weld when the new panel is instaled.
Rust rust rust!!!!!! the underneath sure looked good, well it's not as bad as it looks. The rust is only on the inner and outer rocker. The outrigger you see that looks rusty is only where the undercoating came off after being painted. It is all solid and will be cleaned and repainted when the rockers are instaled.
Here you can get a good idea of the extent of the rust that was hidden, the removal will take some time as there are lots of hard to get to spot welds.
Offline Aircooled Angel
    • http://www.kaferkraft.ca
« Reply #9 on: August 26, 2003, 04:04:38 PM »
Poor little bus. Good thing its your guys's hands now!
« Reply #10 on: August 27, 2003, 08:50:02 AM »
Hey! Look what I found..............More rust!
Offline Rooodie
    • http://www.dglvk.com
« Reply #11 on: August 27, 2003, 09:32:23 AM »
I hope your tetanus shot it up to date :!:
DGLVK
West Coast Show Down 2004
« Reply #12 on: August 27, 2003, 11:29:48 AM »
What a bunch of BUCKETS! Must be nice to have all that time and money.
« Reply #13 on: August 27, 2003, 12:29:54 PM »
Hey Snapper,  Buckets yes, being able to say you did all the work yourself, a great acomplishment................Beating you in the 1/4 with my van PRICELESS!
« Reply #14 on: August 27, 2003, 12:33:42 PM »
Geoff, you must have been talking to Kevin to put a big motor in such a heavy car! We all know what happens then dont we? Seriously, what are the plans for the cars. Give us details, you have the time! :rolleyes:
« Reply #15 on: August 27, 2003, 01:02:44 PM »
Details, well some things are still up in the air (drive train). The bus will have line loc, Slicks mounted on satin centerlines for the track. Street wheels may be a set of 16' phone dials but i'm not set on those yet.
There are a few motor and trans combos im thinking of, 1835cc with small turbo and beetle irs trans with ZF limited slip diff. 2.7 911 motor with stock 002 or 091 bus trans...........or just a hell bent 2275cc with IDA's. This will all depend on the next few swap meet deals i can find. I'm off to Sacramento this weekend for Bug o ramma, maybe i can find some good starting point there.
I kinda like the 2.7L 911 motor but want to stay VW power...............no T4  power so dont even say it.
« Reply #16 on: August 27, 2003, 02:03:24 PM »
Sounds fun, Type 4 means your setting yourself up for dissapointment anyway. Have fun in Sacramento, can ya grab me a shirt?
« Reply #17 on: August 27, 2003, 02:39:02 PM »
whoa boy  easy there............
It depends what you are expecting from a motor.  Obviously you weren't expecting more than 75 miles from yours, who is the disapointed one????  :lol:  :lol:  :lol:
Geoff there is a 911 at mikes autowrecking now,   motor and tranny both in the car.  Front end of car was in a fire.    motor and tranny look fine
« Last Edit: August 27, 2003, 02:39:23 PM by Billyisgr8 »
« Reply #18 on: August 27, 2003, 03:11:19 PM »
Just bought that motor, Thanks Kev. Looks like it will be a 27L Porsche power!!! YeeeeeeeeeeHaaaaaaaaaaaa
« Reply #19 on: August 27, 2003, 03:21:09 PM »
before I mentioned it or after?
You had better had not paid more than $4000 for both.  Mike really needs the money bad.... can you say  DEAL....
Awsome Geoff!!!
that's funny as I just 4 days ago  told another guy about this same motor for his bus.
Offline Meisterman
    • http://www.bulliboys.com
« Reply #20 on: September 03, 2003, 11:17:57 PM »
Hmmm...
I smell a showdown...the Speed E vs. Barry's Carrera Vanagon?
Two generations of VW Busses powered by Porsche...head to head?!?
 :blink:
Don't want to miss that Geoff!
Great pictures and play by play action on the repairs...looking forward to more.
Meisterman
