Author Topic: anyone ever found a good vinyl dye?  (Read 1888 times)
Offline purple turd
« on: February 28, 2014, 07:01:19 PM »
I have a white headliner and would like to go black..sem makes a good spray but lm looking for brush or sponge on. Any ideas?
Re: anyone ever found a good vinyl dye?
« Reply #1 on: March 01, 2014, 09:17:20 AM »
havent done with dye but lots of other stuff i didnt want to spray.....Take the aresol can and flip upside down and spray to remove all the propellant then you can cut the top off the can or just ram a screwdriver in and drain into a container then you can brush or wipe to your hearts content.
have fun, I've had very limited success with vinyl dye in past...works ok changing shade a bit but you are trying white to Black?  can't get much harder to cover?
« Reply #2 on: March 02, 2014, 09:07:36 AM »
Never done this before, but if you prep it properly the dye should work pretty well since its on a area that is not being sat on or used in any way. Make sure you have a good respirator cause that stuff cant be good for ya.
« Reply #3 on: March 02, 2014, 09:08:25 AM »
SEM makes a good product. I believe Lordco carries it. Why do you prefer the brush or sponge?
« Last Edit: March 02, 2014, 09:10:08 AM by red snapper »
Offline purple turd
« Reply #4 on: March 02, 2014, 03:12:14 PM »
Hard to spray a headliner in a car with a complete interior. My own fault for not doing it while it was in a million pieces. Worse trouble now.. engine failure yesterday
