Author Topic: M-5  (Read 1800 times)
M-5
« on: September 27, 2013, 10:06:17 AM »
I am looking to buy M-5 locally. anyone know of a place??? Jim???
Offline dale-j
  • Steve
Re: M-5
« Reply #1 on: September 27, 2013, 02:12:39 PM »
The Repo Depot in South Surrey (King George at Crescent Road) had an E60 M5 a while back, don't know if they do any more but never did look at it as it was an SMG car.  What gen you looking at?
Steve
Re: M-5
« Reply #2 on: September 27, 2013, 03:27:00 PM »
yes another FLAT 4 METH ADDICT  ,thats it im making t shirts
got thinking after we talked and this is the way i see it , i looked it up on the vp site .m5 is not pure meth it contains more combustion additives and more oxygen .( if i remember its 5% nitro )
the spec grav and reid vapor are higher than pure meth .
so for me if i was switching to m5 from m1/pure meth i would need to jet larger on the main /open up 4-5 thou .
so going the other way without jetting change , your going to run richer .which is ok .how much i cant say .double check with a call to kris.
i dont know if you are running a intercooler or not but reid vapor pressure reminds me of the difference between c16 and q 16 .
c16 being better for hot intake and carbs of a vw due to its lower evap rate and q 16 is better in a intercooler as it evaporates at a way lower temp .
-- also from m1 to m5 pull 1-2 more timing due to the nito
so in theory you could add 1-2 deg which would help with a slightly richer mixture
make sence .
since my daughter has switched over to the "EH TEAM" you know your welcome to my meth , come and get it .
also you may want to ask kris to remap for pure meth as like i said i get a 55 gallon drum cheap
Property/
Typical Values
M1
M3
M5   Test
Methods
Specific Gravity
@ 60F
.795
.784
.816
ASTM D 4052
Reid Vapor
Pressure
4.60
8.57
7.66
ASTM D 323
Color   Clear   Clear   Clear
« Last Edit: September 27, 2013, 03:33:52 PM by jim martin »
Re: M-5
« Reply #3 on: September 27, 2013, 08:18:19 PM »
Thanks Jim,
Tell your daughter I will get her a new Brown Sugar shirt
