Author Topic: Start Damn You Start!  (Read 1452 times)
Offline Pipes
« on: June 29, 2004, 01:05:24 PM »
Folks! Just a plee for help from ANYONE that has any experiance with Crank Fire Igntion Setups.  Sounded like a brilliant idea when I first began the build but now I'm ready to drop kick the damn thing!!
It simply will not get the timing right, again and again, I check the notching looks correct, check the cam and crank relationship, perfect, valves are all set, Coils fire flawlessly, plug wires are good, sparks to all cyclinders, crank sensor seems to pick up the signal.  I must have something wrong with the crank pully position or something... GAWD help!  Any Electro-Mechanics out there?
« Last Edit: June 29, 2004, 01:38:27 PM by Pipes »
Trying for low, show & go
1967 Beetle
Offline Scratchy
« Reply #1 on: June 29, 2004, 08:35:01 PM »
Good to see ya got it running Pipes!
http://www.kaferkraft.ca/forums/viewtopic.php?t=1379
What was the problem?
Offline Pipes
« Reply #2 on: June 29, 2004, 11:16:21 PM »
The Crank sensor was wired backwards! Holy crap!  Change the polairty and it fired right up!  :rockon:
1967 Beetle
