Author Topic: joining the bay life style again  (Read 9309 times)
« on: September 14, 2013, 09:27:23 AM »
I've been into the bay life style in the past but really it was just  kind of a recreational thing back then. (westys)
I'm coming out today to say it's full on now. Check it out.
Its got one of these  (AC unit)
and one of these ( Z bed brackets by ZEE products of Oregon)
and what the heck it this?(pic below)
« Last Edit: October 12, 2013, 08:43:54 AM by Hansk »
Re: joining the bay life style again
« Reply #1 on: September 14, 2013, 09:31:34 AM »
Great to see you coming out and showing your Bay Pride!
Any plans or keep it stock?
« Reply #2 on: September 14, 2013, 09:43:28 AM »
It needs a new motor first but later on I'm thinking stock with bigger tires and wheels for a kind of a semi off road look.
Offline westcoast-paul
« Reply #3 on: October 08, 2013, 10:09:04 PM »
what the heck is that?!  (i'm new to bays), but that makes a ton of sense!
« Reply #4 on: October 08, 2013, 11:09:32 PM »
it looks like the old smoke machine/neon light/glitter maker that used to be in that famous bus from the 80's that was aptly named "the baylords rolling discotheque"! ;) :laugh: or it could be some sort of hvac unit...?
either way...sweet ride hans!  :cool:
« Reply #5 on: October 11, 2013, 11:11:15 PM »
No no , I know what that is but what the heck is this
[/quote]
« Last Edit: October 11, 2013, 11:13:16 PM by Hansk »
« Reply #6 on: October 12, 2013, 06:50:58 AM »
Those are the brackets for allowing the rear seat to become a bed
« Reply #7 on: October 12, 2013, 08:19:22 AM »
Don't look like Zee brackets to me, I suspect it's a locking mount for a gun safe or some sort of strongbox.
« Reply #8 on: October 12, 2013, 09:03:20 AM »
OK I've modified my original post to try to clear up any picture confusion . In the last pic I'm asking if anyone knows what it is/was . I think Busdaddy may be on to something but I should add that it seems to have had power supply(red wire) from the battery and ground (green wire) .  I have no idea.
« Reply #9 on: October 12, 2013, 09:52:15 AM »
While the engine was out I cleaned up the engine compartment
« Last Edit: October 12, 2013, 09:58:26 AM by Hansk »
« Reply #10 on: October 12, 2013, 09:58:40 AM »
The battery tray has some surface rust . Thats the extent of the rust on this bus.
« Last Edit: October 12, 2013, 10:05:26 AM by Hansk »
« Reply #11 on: October 12, 2013, 05:16:44 PM »
Zoinks!, that's a nice clean bus!
I hope you plan to do the vapor lines and filler neck while it's easy to get at the tank, a look at the sender wouldn't hurt either.
« Reply #12 on: October 12, 2013, 07:21:25 PM »
Sorry for the confusion, This was the image that was posted originaly.
« Reply #13 on: October 12, 2013, 08:31:14 PM »
Ahhhhhh....those do look just like Zee brackets, nice score!
What's the little silver bracket screwed to the side of the LH wheel well?
« Reply #14 on: October 14, 2013, 11:04:41 PM »
That little bracket seems to be an adjustable stop for the "zee" back rest arm.
« Reply #15 on: June 08, 2014, 11:16:31 PM »
You are right. I won one once, and it came with this bracket. It's for a gun or valuables.
« Reply #16 on: June 09, 2014, 06:59:28 AM »
So what is with the power and ground to it?
