Author Topic: Found Out Finally....  (Read 2850 times)
« on: June 27, 2004, 05:02:37 PM »
Well I finally found out why my car has been acting up - I took my neighbor for a boot today as he couldn't believe that it was fast than his wife's mouse-tang. Hit first no problem, hit second at about 6500 and I lost my clutch pedal and all I could here was rattle-rattle from the back - seems like my clutch decided it had had enough after it's 2-3hours of driving since new.....I'll see you this week Geoff for a new one....
« Reply #1 on: June 27, 2004, 05:11:56 PM »
Geez man that sucks
After seeing you launch from KK today I have to say a 1914 in seabert is looking goooood
-Kirin
« Reply #2 on: June 27, 2004, 06:37:22 PM »
Launch??? Heck I was being nice - I'll show ya a real launch!
« Reply #3 on: June 27, 2004, 06:40:18 PM »
Hope you got a beefed up tranny:p
« Reply #4 on: June 27, 2004, 06:41:50 PM »
It's in the works...
« Reply #5 on: June 27, 2004, 07:14:40 PM »
Dont buy the same clutch again.. :)
« Reply #6 on: June 27, 2004, 07:27:45 PM »
I've ran stock german discs for years - this time I thought hey let's try an aftermarket one.....I'm putting a stock disc back in!
« Reply #7 on: June 27, 2004, 09:02:29 PM »
I think you should let the experts at Airspeed choose your clutch........ ;)
Offline nivag
  • Gavin Lee
« Reply #8 on: June 27, 2004, 09:19:09 PM »
James - I ran a Art Thearan copper head disc in my last car and loved it. It's a little harsh, but man does it hook up. I ran it with a stage 2 Kennedy pressure plate. I think Airspeed has the Centerforce discs which are very close.
« Last Edit: June 27, 2004, 09:20:02 PM by nivag »
« Reply #9 on: June 27, 2004, 11:04:26 PM »
Well as it turns out my negligence was what cost me in the end. I thought \"hey this throw-out bearing looks damn good, why replace it with a new one\" when I installed my engine. It grenaded today, big time. It took out my pressure plate and my throw-out arm thingy in my trans. Lesson learned - you may save 35 bucks in the first place BUT it will cost you more in the long run - build it right the first time!
« Last Edit: June 27, 2004, 11:20:48 PM by James Buchan »
Offline moni
« Reply #10 on: June 27, 2004, 11:43:58 PM »
sorry to hear about yer clutch. shrapnel is never a good sign, but does make for great pics! :huh:  ;)
« Reply #11 on: June 28, 2004, 07:23:57 AM »
DOAH!
that's not good..
I've sieze throwout bearings before but nothing ever that bad...
wow..
-Kirin
« Reply #12 on: June 28, 2004, 09:43:25 AM »
It wasn't the throw out bearings fault it was YOURS! LOL look close ay the PP, There is no colar. You have the PP set up to take a late throw out bearing not a early. (unless the colar fell off and im not seeing it?) This is the #1 mistake people make when instaling a new clutch.... I know I did it myself on my first bug ;)
« Reply #13 on: June 28, 2004, 10:02:02 AM »
Ahh shit - didn't know there was a difference... live and learn I guess. You guys have stock on what I need to fix it right?
Offline Tom H.
« Reply #14 on: June 28, 2004, 11:19:18 AM »
opps! :wub:
Switching to the guided T/O brg is a nice upgrade. I've been doing that to all my tranz. Can't tell by your tranz pix if you can do it the easy way, just drilling and tapping the cast in nubs on around 70 and up cases. There is the aftermarket sleeve thingamabob that can be used also.
 :rockon:  :rockon:
« Last Edit: June 28, 2004, 11:19:47 AM by Tom H. »
« Reply #15 on: June 28, 2004, 12:56:20 PM »
On seabert I ended up modding my pressure plate to late model to fit my big throwout bearing transmission.
Worked like a charm thus far.
-Kirin
« Reply #16 on: June 28, 2004, 01:55:20 PM »
hey james, i have a collar you can have (i just did the late throwout bearing and dont need it)
« Reply #17 on: June 28, 2004, 02:29:50 PM »
Cool bring it to work with ya.
« Reply #18 on: June 28, 2004, 09:08:41 PM »
James you can upgrade to the late style superior TO bearing by installing an adaptor sleeve where the seal goes.  This adaptor sleeve has a seal inside it, and supports the late TO bearing.
The easy way Tom described is to drill and tap the case.  You can only do this to a '70 case. I can tell by the pics yours isn't.
« Reply #19 on: June 28, 2004, 10:01:48 PM »
Ya my case is a '66 one. Is there a way to do it to mine?
