Author Topic: E-brake Cables..  (Read 7385 times)
E-brake Cables..
« on: June 27, 2004, 09:54:58 AM »
So heres the deal.
My car has brake cables but once the clamp that holds the metal ferrule to the back of the drum is installed it won't allow the extra 1/4 inch of travel that I need to get the drum back on due to the shoes being expanded. I've tried 2 sets of cables and the same results.. its almost like my shoes are currently to fat to allow me to hook up my ebrake.... So any ideas?
E-brake Cables..
« Reply #1 on: June 27, 2004, 11:32:21 AM »
Did you try to adjust your brakes?? sounds like they are too tight.
E-brake Cables..
« Reply #2 on: June 27, 2004, 05:09:52 PM »
brakes are fully adjusted in. I did have to sand down the shoes so they would fit in the drum..
-kirin
E-brake Cables..
« Reply #3 on: June 27, 2004, 11:34:19 PM »
Cables undone at the e brake handle?   Shoes and e brake lever  properly set into the slots in that cross bar(between the two shoes)?
Cable sleeve properly set into the pan and/or backing plate?
Just some ideas
E-brake Cables..
« Reply #4 on: June 28, 2004, 07:29:47 AM »
Cables undone.
Can't pull them up enough due to the shoe thickness. Sleeves properly set in and the cross bar is set in. Plus I had another set of eyes look at it so I know I'm not crazy.
