Author Topic: sprintstars on a bay....hardware question  (Read 7352 times)
« on: May 21, 2013, 04:03:44 PM »
So I bought some sprintstars from cip two years ago for the double cab (68) The hardware I bought was directly linked from the wheels. It is for a bus......they only stick out about 1/8" to a 1/4? past the wheel..........anyone? No I am not running spacers.....help???
Re: sprintstars on a bay....hardware question
« Reply #1 on: May 21, 2013, 05:37:24 PM »
Ate these the steel BBT wheels or the alum wheels?
« Reply #2 on: May 21, 2013, 07:40:58 PM »
They are the aluminum ones. The guy at CIP said the 1 1/2" long studs should work.......those are the ones I have now........
« Reply #3 on: May 21, 2013, 10:39:29 PM »
i love key words
« Reply #4 on: May 22, 2013, 09:16:54 PM »
hahahahaha. ya for sure.
« Reply #5 on: May 22, 2013, 09:39:34 PM »
You can get longer studs from most autoparts stores. The drum side will be 14mm, check your lug nuts (look on the side) they will say either 12mm, 14mm, 1/2-20 etc. just order the length you need and let them know 14mm on drum side and whatever you have on the other.
« Reply #6 on: May 23, 2013, 07:53:37 AM »
Ok. Will do. Thanks G.
