Author Topic: Valve clearance with Chromoly Push Rods  (Read 5655 times)
Offline orangecrush
  • Rob McLatchy
« on: May 02, 2013, 03:57:12 PM »
What is the setting when running Chromoly push rods with 1.25 high ratio rockers?
The block is a EMPI H.D. engine case 94mm 10mm Case Studs
69mm 4140 Chromoly Counter-Weighted Crank 8 dowel
4140 Chromoly I-Beam Rods
5 1/2 LB Crankshaft Pulley
Lighten flywheel
Mahle 94mm forged pistons
Hi-Performance heads Single Spring 3 way valve cut, 35.5 exhaust 40mm intake
Engle W110 Cam with 30mm lightweight lifters
Stainless Steel Windage push rod Tubes
1.25 High-ratio Rockers with Chromoly Push Rods
High capacity oil pump
1.5 qt High Capacity Oil Sump
40 IDF Weber Carbs
Protronix Distributor with Flame Thrower Coil
The Crank,Rods, Pistons,Flwheel, Front pulley are all balanced
I have the valves set @.006
Rob
1957 dune buggy
2002 beetle
Re: Valve clearance with Chromoly Push Rods
« Reply #1 on: May 02, 2013, 04:27:19 PM »
Chromoly pushrods are usually set to "loose zero". You adjust them so that the rocker has no play, but you can still rotate the pushrod with your thumb and finger.
Offline orangecrush
  • Rob McLatchy
« Reply #2 on: May 02, 2013, 05:47:24 PM »
Thanks Dave for the info...I've been on the Samba site where they were talking about valve clearances and they suggested the samething you said. I think to be on the safe side is that I'm going to set them @.002 . What do you think?
Rob
1957 dune buggy
2002 beetle
« Reply #3 on: May 02, 2013, 06:38:33 PM »
I'd go with whatever Darren Krewenchuk says (K-Roc)...but I was at his place last week and he confirmed loose-zero with chromo pushrods was the way to go for me.
« Reply #4 on: May 02, 2013, 07:10:39 PM »
What did the engine builder set them at?
« Reply #5 on: May 04, 2013, 07:10:26 AM »
Always set loose zero, the lash will open up as soon as the engine warms up. If you set them to anything other they will make noise when warm.
Offline orangecrush
  • Rob McLatchy
« Reply #6 on: May 04, 2013, 11:38:24 AM »
I think there were set @.004
Thanks everyone for all info  :great:
Rob
1957 dune buggy
2002 beetle
